Front-passenger ride suspension broken?
Old 02-20-2009, 12:11 PM
fireman1559's Avatar
that looks like a traction bar and that is the rear of a stock looking 4runner
Old 02-20-2009, 12:18 PM
904_runner's Avatar
edit:
The blue part you showed is the sway bar link.
The red circle is the lower driverside link. ALso how are your shocks back there and in the front if it is still leaning?
Old 02-20-2009, 12:22 PM
angryj's Avatar
I was going to say - did anyone even read the post?
It's kind of buried in the post but Red oval = traction bar, which I re-bent the mount for, and Blue circle = sway bar connect, which I cannot get the bottom bolt off of. Is there an easy way to keep the lower bolt from spinning?
Old 02-20-2009, 12:33 PM
904_runner's Avatar
Don't you need two wrenches to get that link off? so it doesn't just spin?
Also how are your shocks back there?
Old 02-20-2009, 12:43 PM
  #25
angryj's Avatar
Shocks seem fine - as for the two wrenches, so one on the inside bolt and another in between the right-angle? Doesn't look like there's anything in there to wrench onto and there's no bolt coming through to the outside.
Old 02-20-2009, 12:44 PM
  #26
904_runner's Avatar
Hum i thought there was a spot for two wrenches so it doesn't move when you are loosing it. Maybe thats just for the endlinks that attach to the frame.
Id run out and look but im at work.
Old 02-20-2009, 12:47 PM
  #27
angryj's Avatar
It looks just like this, see the left front -there's no end to grab onto in order to keep that back bolt from spinning
Old 02-20-2009, 12:50 PM
  #28
904_runner's Avatar
just keep turning it then..
Old 02-20-2009, 01:34 PM
  #29
mt_goat's Avatar
I have been working an my 95 Taurus and ran into the same problem yesterday. The sway bar links have a little ball joint with a stud coming out the end of the ball and a nut on the end. I tried turning the rusted nut but the whole thing turns inside the ball joint, ball and everything. I finally had to cut the ball socket off and get a pair of visegrips on the ball to remove the nut and get it apart. The 4runners must have a similar set up. No reusing those things.
Old 02-20-2009, 01:37 PM
  #30
angryj's Avatar
So much for pounding this link and re-using it. At least I know I'm not crazy now. Thanks for the confirmation!
Old 02-20-2009, 01:43 PM
  #31
904_runner's Avatar
well you still might be a little crazy..
Lol
ive never tried to take mine off.
Scottcrb
03-03-2016 11:57 AM
kportercpa
Engine Swaps
09-10-2015 12:08 PM
icentropy
09-10-2015 05:03 AM
justdifferentials
09-05-2015 06:52 PM
BigMike
Marlin Crawler
09-03-2015 07:49 PM
Quick Reply: Front-passenger ride suspension broken?
