Front end shimmy in 4x4 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-26-2008, 03:30 PM   #1 (permalink)
Howdy folks - I've been lurking for a few months and picked up a lot of good info, but this is my first post.
I picked up a 1992 Toyota 4runner with 214,000 miles on it back in March. It's v6, 4x4, 5 speed, and runs pretty good though it needed some miscellaneous work when I bought it. (new windshield, new brakes all around, new hubs, got the rear speakers working, got the antenna working, got the drivers power window working right, new gas cap, new steering wheel cover, new floormats, and a few things remaining to be done) I don't drive it too much (it's a bad weather/off-road/camping beater for me) so I've only put about 1,000 miles on her.
It didn't have any hubs on it when I bought it (and obviously didn't have working 4x4, but the previous owner swore it worked just fine, but he had to take the hubs off for some unknown reason), so I picked up some Warn manual locking hubs. With the hubs in 4x2, the truck handles just fine at highway speeds. With the hubs in 4x4, whether 4x4 is active or not, she gets a pretty wicked shimmy from the front end beginning at about 40mph, pretty bad by about 50 and I've been too scared to go over 60. Any ideas what it could be?
I've seen some other threads that recommend checking the U-joints for play. This is the first time I've worked on a 4-wheel drive, so I'm a little new to the terminology. Are the U-joints what connect the front driveshaft from the tranny to the front diff? How do I check them for play? I got under the car and tried to move things around, but didn't find anything loose.
JGordon is offline
Old 06-26-2008, 04:17 PM   #2 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
May I ask...
...what type of roads are you driving it on, at 40+ miles per hour with the hubs locked?
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 06-26-2008, 07:29 PM   #3 (permalink)
well if you'd have been driving down the atlanta highway, you'd have known the tin roof was rusted.
__________________
Old 06-26-2008, 07:50 PM   #4 (permalink)
CJM
CJM's Avatar
You need to remove the front driveshaft, then check the u-joints (you will see them, they look like universals joints for sockets) and if they dont move easy as pie its time for new ones.
YOur not supposed to be going 50mph + in 4wd anyways, I surely hope its on dirt roads too. Pavement and 4x4 = no!
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 06-26-2008, 08:08 PM   #5 (permalink)
Quote:
I'm not driving in 4x4, I'm driving with the hubs in 4x4 but the 4x4 shift lever in 4x2. So no power is going to the front wheels, but the front diff is still turning. With the hubs in 4x4, but the shifter in 4x2, this is essentially the equivalent of driving the truck with the stock hubs on and 4x4 disengaged. The aftermarket hubs merely give me the ability to disconnect the front diff totally, so that the wheels turn freely.
This isn't a huge deal because I can always get out and manually switch the hubs before I engage the 4x4 shifter, but sometimes it's nice to have the "shift on the fly" capability that locking the hubs in 4x4 gives.
JGordon is offline
Old 06-26-2008, 08:37 PM   #6 (permalink)
CJM
CJM's Avatar
Oh ok, you have the hubs locked but not in 4wd. Sounds like your u-joints are bad or the shaft is out of balance.
__________________
CJM is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
94 4x4 P/U front end - wrecked - need complete Perpendicular The Classifieds GraveYard 3 03-20-2008 08:45 AM
shimmy in front end on my 2000 tacoma ttowntoy 95.5-2004 Tacomas & 96-2002 4Runners 2 06-06-2006 05:08 AM
Rear end shimmy - 3rd Gen 4Runner 22re-efer Offroad Tech 4 08-10-2005 07:45 PM
2003 4th gen Front end shimmy cervesa33 03+ 4Runner/GX470, & 05+ Tacomas 6 06-13-2005 11:46 AM
front end on '96 tacoma 4x4 (Again) toyotafan 95.5-2004 Tacomas & 96-2002 4Runners 0 04-21-2003 08:17 AM
2009 InternetBrands, Inc.
