| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
? on front end, balljoint?
#2 (permalink) |
Yes bad ball joints are a good one for making those nice loud popping sounds. If you have a bad ball joint also the vehicle may wander around the road a bit especially if your doing a slight turn.
To test your ball joint: -jack up one side of the vehicle only (the side your checking) use the lower A-arm as your lifting point, and only go up 2 or 3 inches. -use a pry bar, 2x4 or anything else of that type and put it underneath the tire, and push up on it with considerably force. -if the wheel moves directly up and down even slightly without the suspension moving(coilovers, or in your case shocks because you have torsion bars) then the balljoint is bad. Additionaly you might visually inspect the ball joint. not much you can do in this case but if you look at it and notice that the grease boot that goes around it is cracked or split then it is for sure toast. EDIT Ive never done a balljoint on an older 4runner, but the nice thing is that if you do have to replace it you can go ahead and hammer the old one off using a pickle fork. pickle forks are typically a pain because they often split the grease boot if you use them to get the old balljoint off, but if yours is already toast thats not an issue. Pickle forks have a range of different sizes and are usually about $10-$13. hopefully somebody who has done several of these will chime in but worst case scenario if a pickle fork is not an option (which is the case with some older press-fit ball joints) you can remove it using a C-press which costs about $60.
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress. 85 pickup, 327sbc, truggy, in progress. 86 mazda b2000 street queen haha. 92 mazda B2600i 4x4 absolutely mobs. 81 ford bronco drinks gas 90 mazda mx-5 all original. when in doubt, tach it out. Last edited by apalmer1; 05-14-2008 at 08:08 PM. |
#3 (permalink) |
Could also the steering stops
__________________
95 4Runner- 3vze- A/T- 4.88's Currently LC Coils BJ Spacers SAW T-Bars 32x11.50 BFG A/T's 15x8 black Rockcrawlers Marlin Crawler rear bumper |
#4 (permalink) | ||
If its a ball joint, they are fairly easy to replace, I am able to do all 4 in my truck in under 2hrs, tools you wil need... pickle fork, 10 mm socket, 12mm socket, hammer, jack... you dont even have to take the hubs apart, disconect the shocks from bottom a frame, then pop the upper bj, when you are ready to put it back in use a jack to raise the hub assembly,, then do the bottom.
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 233k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 235k on the clock. It's becoming an addiction. |
#5 (permalink) |
I would check the condition of the ball joints before replacing...it very well could be the infamous steering stop noise
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
| Tags |
| 2x4, arm, b2600i, end, front, popping, truggy |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front End | Justinvd | 86-95 Trucks & 4Runners | 7 | 10-23-2007 11:49 PM |
| Front end help please | 95toybox | 86-95 Trucks & 4Runners | 5 | 03-10-2007 04:09 PM |
| YotaTech getting new front end | Corey | Site Feedback | 5 | 06-04-2006 01:15 PM |
| Front end rebuild ??? | Kyle95sr5 | 86-95 Trucks & 4Runners | 8 | 01-12-2006 04:54 PM |
| front end higher than the back end? | Allyia | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 07-20-2005 12:44 PM |
