YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 06-25-2009, 09:00 PM   #1 (permalink)
Personal Sales Rating: (0)
Exclamation FORGED PISTONS and KNOCK SENSORS
Just incase you're not aware of it, when rebuilding your engine and going with forged pistons, the knock sensor MUST be moved to the lower boss on the side of the block.
These pistons don't warm up as fast as cast ones do, and they send a harmonic pinging sound to the sensor which in turn sends more fuel, that's not needed. Drill and tap the lowest free boss under/below the sensor and install knock sensor there. BE VERY CAREFUL NOT TO DRILL DEEPER THAN NEEDED!!! Or you'll have a nice hole in the side of the block!! I found no need to drill deeper than what was already there, just a little larger to accomodate the Tap.
Just something to think about when building your engines
HAWK4295
HAWK4295 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 06-25-2009, 09:08 PM   #2 (permalink)
874runnersr5's Avatar
Learn something new everyday, great info im sure itll help alot of people!
__________________
87' 4runner Sr5 :Little lift, bumpers to bash junk, and more jeeunk in my build thread -sold
874runnersr5 is offline
Old 06-26-2009, 02:39 AM   #3 (permalink)
abecedarian's Avatar
Here's another new thing to learn:
The knock sensor doesn't send more fuel- when the ECU detects detonation via the knock sensor, the ECU to drops the timing advance out (retards the timing to baseline) in order to prevent detonation. The sudden change in timing produces the same effect as if the engine were to suddenly get more fuel.
Also, forged pistons expand more when heated than cast ones do. This means forged pistons are slightly smaller than cast ones so that they have the same diameter and wrist pin clearance as cast do when warmed up. This looseness when cold causes 'slap' which the knock sensor can detect and if the signal is 'loud' enough, will trigger the ECU's response as if the engine were detonating. This is why moving the knock sensor lower in the block can prevent the problem with the timing changing when it shouldn't. However doing so also prevents the knock sensor from hearing the moderate detonation it should be able to hear.
__________________
Proud member of Yotatech's 12000+ post club.
*** Still active May, 2013 ***
CX500TC motorcycle EFI upgrade still in progress.
abecedarian is offline
Old 06-26-2009, 07:24 AM   #4 (permalink)
Dirt Driver's Avatar
Send a message via AIM to Dirt Driver
Quote:
Yeah, I was going to say that many knock sensing systems are tuned for a very particular application and that moving the sensor might render it largely ineffective.
__________________
Aka Dirty Dude.
2000 TRD SR5 PreRunner. - Black sand metallic, extra cab, 3.4L.
Dirt Driver is offline
Old 06-26-2009, 08:03 PM   #5 (permalink)
Threadstarter [OP]
Quote:
I was going by what LC Engineering has recomended, they found out through YEARS of building 4 cylinder Toyota engines.
I haven't had any problems.
HAWK4295
HAWK4295 is offline
Old 06-26-2009, 09:50 PM   #6 (permalink)
Kay....dodo those YEARS include datalogs and comprehensive testing, or just "I didn't hear anything, so it must be alright"?
__________________
Aka Dirty Dude.
Yotatech
4WD Truck
Paid Advertisement
Tags
22, 22re, dirt, driver, engineering, expand, forged, knock, knocking, location, pistons, relocating, sensor, tapping, toyota, v6, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
