Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
Finding TDC (compression) 22RE
__________________
Kyle H Current Yotas: 86 4Runner deluxe 5spd 03 4Runner Limited 4wd Former: 98 4Runner SR5 3.4 99 4Runner Limited 3.4 (RIP...kind of) 90 4Runner SR5 3.0 87 4Runner Deluxe 22RE 86 4Runner Turbo (RIP) |
#2 (permalink) |
Personal
Sales Rating: (1)
#1 piston is at the top and both rockers are loose on number 1. or you can take the spark plug out and put your finger over the hole and turn the motor with a wrench, when air pushes out you are coming to tdc. were the wires in the right hole on the dist. cap?
__________________
89 Truck X-tra Cab LCE Timing Chain LCE Header 31'' Maxxis Buckshot 4.88's built by ZUK(the mind reader) Aussie Locker Front and Rear 63'' Chevy Springs Marlin HD Clutch Bilstein HD Shocks 2.5" Exhaust W/Dynomax Muffler 2-50 Watt Backup Lights Last edited by TORTIS; 03-09-2008 at 03:39 PM. |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
I assume the wires going to the distributor cap were accurate. I can't see it working otherwise. For reference, the #1 cyl (the one closest to the front bumper) plug goes into the "11 oclock" position.
Sorry for the newb question, but by "both rockers are loose" what do you mean, or how would I check this? Thanks
__________________
#4 (permalink) |
Personal
Sales Rating: (1)
they may have been a tooth off on the dist. install and move wire to compensate.
__________________
89 Truck X-tra Cab LCE Timing Chain LCE Header 31'' Maxxis Buckshot 4.88's built by ZUK(the mind reader) Aussie Locker Front and Rear 63'' Chevy Springs Marlin HD Clutch Bilstein HD Shocks 2.5" Exhaust W/Dynomax Muffler 2-50 Watt Backup Lights |
#5 (permalink) | |
Personal
Sales Rating: (0)
Quote:
#6 (permalink) | |
Personal
Sales Rating: (0)
Location: NW Ark on wooded ten acres...Ozarks at large!
You say the engine was running like this? Has it always been like this as far as you know? And, you ran a compression a test?
__________________
Matthew Context is everything.... Quote:
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Yeah- ran great. And I did do a compression check and all cyl dees were within minspec, except that one was too far below the other cylinders for consistency spec. Did a leakdown test and found that cylinder was pushing air into the coolant.
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
Yeah that definately doesn't look right. Here was mine at TDC on the compresssion stoke last weekend when I pulled the head:
![]() You can tell if you are on the compression stoke if the crank is hard to turn with a ratchet. It will go easy, hard, easy, hard, etc. You must be off a tooth on the distributer. I'm surprised it ran well. I had it off one tooth last winter when I did my head gasket and I wasn't able to get the timing right. When you go to put it back in, make sure the engine is at TDC and insert it with the rotor at 12 o'clock and it will rotate counterclockwise where it needs to be so it will idle and you can set your timing. Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s - SOLD January 2010 - |
#9 (permalink) | ||
Personal
Sales Rating: (0)
Quote:
So, good you're having the head checked. That rotor is way off.
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
This has been the most reliable way for me... If it ran fine how it was don't change it...mark the dis. bolt where it is now...mark the rotor where it is now...slowly pull it out and mark where the rotor ends up(makes it easier to put back in) That's how I've done it quite a few times
__________________
www.tinbenders.org |
#11 (permalink) |
Personal
Sales Rating: (0)
[OP]
When the engi e really is at tdc the distributor is indeed at the 11 oclock position. That would mean the crank pulley indicator is out of whack. That is the correct "notch" in the pulley I should be looking for, right?
__________________
#12 (permalink) |
Personal
Sales Rating: (0)
The notch should be on 0 when both #1 valves are closed..IMO it's more likely that the dis. is a tooth off than the crank pully notch is wrong.
__________________
#13 (permalink) | ||
Personal
Sales Rating: (0)
Quote:
__________________
#14 (permalink) | |
Personal
Sales Rating: (0)
Quote:
I think he was getting too caught up in where that rotor was when the valves and timing mark will tell you for sure when your at tdc..by marking it at least he has a reference to put it back how it was(sais it ran great) edit.. to add to that..every time that I've thought the timing mark was off I've found that I overlooked something
__________________
www.tinbenders.org Last edited by Aaronn; 03-11-2008 at 06:37 AM. |
#15 (permalink) | ||
Personal
Sales Rating: (0)
Quote:
I think what's scary here is that with the rotor way out of time like that, the motor even ran without doing valve damage.
__________________
#16 (permalink) |
Personal
Sales Rating: (0)
[OP]
Hey guys, I did remove the head, I believe in TDC position. The crank sprocket was in the right spot, as was the distributor pointer. The crank pulley notch however was in about the 7 oclock position rather than pointing at 0* on the timing cover. I went ahead and made my own notch though before removing the chain and sprocket at the top and marked them accordingly so that I can hopefully get the right timing when I put things back together. Here's a picture of the head when I removed it, so I think everything is in the "correct" position.
![]() Pretty isn't it. I'll be starting another thread that's more of a "help me" thread complete with pictures and comments from along the way. I'll come back here and link to it for reference. Thanks again for the comments! Link to updates/snags as I continue the headgasket procedure http://www.yotatech.com/f116/head-ga.../#post50776338 Kyle
__________________
Kyle H Current Yotas: 86 4Runner deluxe 5spd 03 4Runner Limited 4wd Former: 98 4Runner SR5 3.4 99 4Runner Limited 3.4 (RIP...kind of) 90 4Runner SR5 3.0 87 4Runner Deluxe 22RE 86 4Runner Turbo (RIP) Last edited by My99; 03-11-2008 at 07:27 PM. |
#17 (permalink) | |
Personal
Sales Rating: (0)
Alright, Kyle!
That is TDC....and that would mean the pulley notch was off. Weird. But! That also means your timing wasn't actually off and no bent valves. Well, the fact that it was running great was a good indicator regardless. Anyway, good news, eh? Looks like #4 piston got a little steam cleaning....
__________________
#18 (permalink) |
Personal
Sales Rating: (0)
#19 (permalink) |
Personal
Sales Rating: (0)
ditto. I have an '88 POS runner in my garage now that has the same issue including the lack of compression on all four cyls. Turns out two owners prior to me had the crank timing gear break and locked up the valve train and kissed the pistons. It sure looks like the crank pulley has a rubber layer between the center portion and pulley groove that somehow slipped. If you're going through the work to replace the HG (chain too) replace the pulley as well. Do it right the first time.
__________________
'94 80 w/ some stuff '88 runner stock 3.slow |
| Tags |
| 22r, 22re, 4runner, center, compression, dead, definition, find, finding, head, piston, put, set, tdc, top, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| High Compression 22re | JASON 22RE | 86-95 Trucks & 4Runners | 18 | 05-22-2007 10:03 PM |
| 86 22re compression results | SoCal4Running | 86-95 Trucks & 4Runners | 1 | 01-16-2007 08:40 PM |
| 22RE compression ? | 4RunnerLVR86 | 86-95 Trucks & 4Runners | 2 | 10-31-2006 04:37 PM |
| 22RE With NO Compression | 4RunnerLVR86 | 86-95 Trucks & 4Runners | 25 | 10-06-2006 11:49 AM |
| 22re compression tests | L33T35T 4Runner | General Vehicle Related Topics (Non Year Related) | 5 | 07-15-2006 04:59 PM |
