Evap/charcoal canister alternatives
Old 04-21-2009, 03:01 PM
PMSmith's Avatar
I've searched the forums and found a lot of good info, however my specific question is if I need to replace the charcoal canister, what are my options?
Replacement for one on an 89 4Runner 22RE costs something like $250-300 at autozone. Are there less expensive alternatives?
Story: Just bought the truck and doing some things to it. Still needs the coolant flush and the exhaust repaired. One of the issues I was putting off was the extra pressure build up in the fuel tank, lots of air when removing the cap. I changed the gas cap and plan to get another after reading of a bad experience with the Autozone cap. The charcoal canister was leaking fuel from the air tube on the bottom, so I assume they are related. I pulled the canister and blew air into it and found it to be blocked, which is why I believe it needs to be replaced.
Any help, advice, suggestions, something I missed; letting me know will be greatly appreciated.
Old 04-21-2009, 03:47 PM
scuba's Avatar
for a cheaper solution call up member deathcougar and get a used charcoal canistar.
search nix99
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
Chicken12
10-14-2015 03:54 PM
Badlander
10-10-2015 08:05 PM
SCZIG
09-20-2015 09:00 AM
Quick Reply: Evap/charcoal canister alternatives
