Engine Swap HELP!
Old Apr 14, 2007 | 03:48 PM
alaskanrocket's Avatar
Engine Swap HELP!
I am currently in the middle of an engine swap on a 86 pickup with a 22r. The right hand 17mm bellhousing bolt can not be gotten to with either a box wrench or socket because the slave cylinder mount on the bellhousing is too tight against the bolt.Anyone have any helpful hints. I tried to grind down a socket to get a thinner wall but it just broke, has anyone had this problem?? Thanks in advance. Jess
Old Apr 14, 2007 | 04:03 PM
TNRabbit's Avatar
ummmm....take the slave cylinder off?
Old Apr 14, 2007 | 04:04 PM
Its off its the bracket that is cast into the bellhousing thats in the way.
Old Apr 14, 2007 | 05:10 PM
longhungsilver's Avatar
I had that problem when i did my clutch... Luckily my friend had a really thinwalled socket... So that might be your best bet to go out and buy one
Old Apr 14, 2007 | 05:36 PM
justinking060310's Avatar
you cant put the open end of the wrench on it?
i know it sucks and takes forever, but you gotta do what you gotta do right?
kat
Old Apr 15, 2007 | 10:43 AM
I got it. I ended up putting on a socket and beating it on with a hammer. Seemed to do the trick. Thanks for the input.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
