Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#21 (permalink) | ||||
Personal
Sales Rating: (0)
__________________
1993 4Runner SR5 3.oh 5speed 232k+ miles. Mostly for the trails and beach. Mods so far: Thorley headers, 4.30 gears, Rancho 5way shocks, AISIN hubs, LockRight rear locker, no sway bars.....32x11.50 BFG M/T's on 15x8 Cragar Soft8's. |
#22 (permalink) |
Vendor
Sales Rating: (10)
#23 (permalink) |
Personal
Sales Rating: (0)
Looks good Wabbit , I wish I had the time to do disc brakes .Welcome Back Abe.
__________________
'89 2wd X-tracab,W55,22re,My DD '94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD '88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907, XRC8, HM Roof rack.33x10.50,15 KM2 1" HM body lift, BJ spacers ,CB, rear disc ,lockright rear, Truetrac front,HM IFS truss,HM sliders,HM rear bumper,HM crossmember,CO2,2 batts,softopper. My swap thread http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/ |
#24 (permalink) | |
Personal
Sales Rating: (0)
What did you do with that brake line hanging? That would be the one that tee's into the right front brake, no? How did you plug and remove it since it doesn't show in the later photos?
Quote:
__________________
Proud member of Yotatech's 12000+ post club. *** STOLEN TRUCK ALERT *** *** Still active May, 2013 *** CX500TC motorcycle EFI upgrade still in progress.
#25 (permalink) |
Personal
Sales Rating: (0)
Well, all I remember when I did my rear disc kit was replumb the lines up front by the passenger front wheel well and out back by the lspv there by rendering in inop. Then plumb in the proportion valve by the master cylinder like Wab. It's been a LONG time since I did it.
__________________
Logan aka: BBP Kiss my IFS. RB4R-VP. '86 4Runner SR5 TRD 5VZ-FE ...slightly modified from OEM... PACK IN, PACK OUT '06 4Runner Sport 270/65R17 BFG AT's |
#26 (permalink) |
Personal
Sales Rating: (0)
I used a M10x1.0 bolt with a nut to plug the tee. I tightened the nut just to make sure it doesn't come loose. I left the line. It looked like alot of work to remove and I didn't see any need to remove it.
__________________
#27 (permalink) | |
Vendor
Sales Rating: (10)
Quote:
#28 (permalink) | |
Personal
Sales Rating: (0)
Quote:
That looks like from the front / right wheel but I don't see the crimp.
__________________
#29 (permalink) |
Personal
Sales Rating: (0)
If you look between the left 90 degree fitting and the right "T" fitting you can see it. The left side of the "T" has the crimp thingy.
Is that right Wab?
__________________
#30 (permalink) |
Vendor
Sales Rating: (10)
#31 (permalink) |
Personal
Sales Rating: (0)
ahh... I see it now. looks like it's laying on top of the other line. But I see they're both crimped.
my apologies.
__________________
#32 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Ohh I see so it backfeeds onto the spring to cause less flow. But once the system equalizes how does the pressure drop? While adding pressure you can limit the flow which causes a pressure drop but once the flow stops how do you get rid of the pressure? I can see how it works on gas and hydraulics that are moving but in a brake system the flow becomes stable. In a closed pressure system isn't all the pressure the same unless you have flow somewhere? I must be missing something or putting to much thought into this.....
__________________
95 22re extra cab, custom box, 4:56, 31inch tires, electric fan, Flat black paint, 4 runner buckets and mirrors WANTED: 1st Gen Pickup 4x4 project. |
#33 (permalink) |
Personal
Sales Rating: (0)
maybe this will help: http://autoshop101.com/forms/brake08.pdf
__________________
#34 (permalink) | |
Personal
Sales Rating: (0)
Quote:
__________________
#35 (permalink) |
Personal
Sales Rating: (0)
I agree.
It explains how proportioning valves work and demonstrates the different types found on various vehicles, why they're there and such and offers some compelling reasons to not remove them. But, I'm guessing it makes more sense now?
__________________
#36 (permalink) |
Personal
Sales Rating: (0)
Just got this done last weekend
Quote:
__________________
-Keith- General License Ham '88 4runner SR5 - 3.0 7MGE eng swap - Marlin HD W56 - 4.88 e-locked & LSD - 33x10.5 BFG KM2's - NWMP Aux Gas Tank - OME Dakar rear springs w/ Bilstein 5150 reservoir shocks Garage Thread "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond |
#37 (permalink) |
Personal
Sales Rating: (0)
I hope you moved the breakline where it goes into the rear drum brake. I don't think the brake line can take the weight of the truck.One land on the rocks and it's over.
__________________
http://www.angelfire.com/ca6/954runner GOD's Country Best Seen In A 4 Runner. SAS'd front: ARB,Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1, 5.29. ..."But officer, that was not an illegal turn, it was just an undocumented turn." |
#38 (permalink) |
Personal
Sales Rating: (0)
I just removed my LSPV (rusted out and too expensive) on my '89 4wd pickup, capped the front drivers side return hole, hooked up to the "T" in the back through the rear brake line, bled the brakes. I wanted to use the truck temporarily until my prop valve comes. My problem is that my brake pedal goes all the way to the floor when I start it and I have no brakes at all unless I push them all the way to the floor. I can pump the brake pedal and it firms up, when it's not running. What did I do wrong? Any guidance would be most appreciated.
#39 (permalink) |
Personal
Sales Rating: (0)
Edit - My brake pedal is not stiff and does not pump up. It travels all the way to the floor with little to no resistance. Is that Master Cylinder or could air in the line do that too? Thanks.
#40 (permalink) |
Personal
Sales Rating: (0)
I did this about 3 weeks ago and I am glad that I did. It was a free and easy fix. I just cut the rod that was connected to the rear diff and then tied it up. I noticed a big difference when I apply the brakes now. Hope this helps.
Jeremy
__________________
I did have a 1990 X-cab P/U, 3.0 SAS'd w/ 3" Trail Gear IFS Eliminator Kit, 4" Trail Gear Rear Lift Kit, 35" KM2s, Yukon 4.88s, Locked Front and Rear w/ Aussie and a Detroit, Sliders, M-8000 Warn Winch, But I sold it |
| Tags |
| adjustable, bypass, homemade, load, pick, pickup, porportioning, pressure, proportioning, removing, sensing, toyota, truck, valve, valvetacoma |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 89 toyota truck load sensing proportioning valve | bvrettski | 86-95 Trucks & 4Runners | 29 | 12-13-2011 03:27 PM |
| Fixing Load Sensing Proportioning valve ? | littlecommando | 84-85 Trucks & 4Runners | 4 | 03-10-2009 05:27 PM |
| (brakes) Load Sensing Proportioning Valve | semo | Pre 84 Trucks | 14 | 01-31-2008 09:10 PM |
| need to find load sensing proportioning and bypass valve | andrew241 | 86-95 Trucks & 4Runners | 10 | 08-13-2007 04:54 PM |
| load sensing proportioning and by-pass valve | nicka | 86-95 Trucks & 4Runners | 1 | 11-22-2006 03:52 PM |
