dual rear axle 4x4?
Old 10-30-2010, 02:07 AM
Rusted Rooster's Avatar
dual rear axle 4x4?
Anyone know if a toyota dual rear end, like out of an old yoda u-haul will bolt up to a 87 4x4 truck?
always wanted a 4x4 yota dulley,,, any help would be great!
And are the 1 ton dulley truck frames the same as standard ones,,,guessing just the leaf springs are bigger, that makes it called 1 ton? Thanks again.
Old 10-30-2010, 07:10 AM
lephturn's Avatar
Probably would. I think I remember seeing a lifted 2wd dually all customized. Wish I had pics ofit.one thing to remember Isis the rear end gearing has to be the same as the front or havoc will happen. I know first hand when I changed the gearing in my ram dually.
Old 10-30-2010, 07:23 AM
needsomecam's Avatar
i have a dually and yes the rear end will fit yur truck. the dually rears are 4.10 gears and are the standard 8in rearends, so if you want a locker you wont have a problem doin so. fyi 1 ton trucks are long bed 2wd trucks with an added girdle to the front end, and large leaf packs in the rear.
--chris
Old 10-31-2010, 04:03 AM
Thanks for feed back guys! I learn so much on this site.
Old 10-31-2010, 08:05 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
arent the rims a funky, odd bolt pattern?
And you think you want a dually, but you'll be over the hard to find tires and goofy looks before too long.
It'll take you longer to find and match all the parts you need...
Old 11-01-2010, 01:45 PM
parts aint to hard to get, yes there is only one style rim for them but they are a 14 in rim so there are plenty of tires out there tht will fit
Colington
03-08-2020 09:51 AM
jerusry
10-19-2015 05:28 PM
ItsJustD
07-07-2015 07:49 AM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: dual rear axle 4x4?
