| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
The Jungle Runner 88 4runner, 22re, 2" 4crawler body lift, custom aluminum interior panels and lock box, Downey Air Intake, Procomp 31x10.5 M/T Tires, My 1st Yota 4x4, purchased March 07 My business: ProgressiveApps.com |
#2 (permalink) |
i should add that when driving after the loud tapping started, i had to give engine a little gas at stops to keep it running or it would stall
__________________
#3 (permalink) |
might have busted those worn out timing guides and the chain jumped a tooth? tapping noise would be the chain slapping the timing cover and the idleing rough would be the engine out of time? just a thought
__________________
new to me 86' toy on 35" procomp mud terrains, with a 4" lift and 3" body and palm fron camo for now... 04' Dodge 2500 4x4 QC hemi leveled, home made CAI and flowmaster exhaust |
#4 (permalink) |
yoterr, thank you for the reply
yes, looked at the guides/dampers, still not sure if they are sometimes called dampers as well ... they look broken when looking down on them with timing cover still on In-store Metal Timing Guides in Southern California!?!?! Anyone!?!?! Know a place?!?! guy on the phone at autozone said, metal guides are louder. ha!! it's all about utility, not luxury ... i have the top off most of the time anyway
__________________
The Jungle Runner 88 4runner, 22re, 2" 4crawler body lift, custom aluminum interior panels and lock box, Downey Air Intake, Procomp 31x10.5 M/T Tires, My 1st Yota 4x4, purchased March 07 My business: ProgressiveApps.com Last edited by jungle_runner; 06-23-2009 at 06:47 PM. |
#5 (permalink) | |
Quote:
![]() I HIGHLY doubt you'll be able to get steel guides anywhere over the counter, unless engnblr or LCE is in the neighborhood ![]() You can get the kits online easily. I'm installed the engnblr kit with my 22re rebuild, that has a steel DRIVER'S side guide only, as they are most common to break, and that's the side that the chain can ware into the water pump housing. Also, the guide is steel, but is rubber coated, so it's not doing to make any more noise than an OEM plastic one, untill the rubber wares off anyway ![]() As far as the names, most will just call the 2 side plastic rails that the chain runs against the guides, and the spring loaded thing at the bottom that presses on the chain to keep it tought the tensioner Before I tore down my engine, I had an obvious brakage with my driver's side guid: ![]() ![]() the new kit from engnbldr consisted of both sprockets (cam and crank), the chain, the tensioner, both guides (as well as new bolts for the guides), timing cover gaskets, and a new front main seal: ![]() ![]() Now LCE offers a kit as well, that looks like both the guides are metal; bare metal at that; no rubber coatings on these guides... it's also a little more pricy, but that's cause it bares the LCE name ![]() Also, I think the dropping off the ledge and this happening is probably coensidence but just maybe the jar was all it needed to make the guide fall apart the rest of the way. Once my guide and tensioner failed, I developed a HORRIBLE as well, so it's very possible this is your problem
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace Last edited by iamsuperbleeder; 06-23-2009 at 07:03 PM. |
#6 (permalink) |
iamsuperbleeder, you're the best! thanks for taking the time to write this up AND post some awesome photos! you
![]() that photo of the broken guide vs the new ones on the engine really made it clear to me that they are in fact broken ... i am going to order the LCE or engnbldr kit and support the guys who support us ... thank you again
__________________
#7 (permalink) |
no problem buddy; we do what we can
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace |
#8 (permalink) |
i just finished rebuilding the front end and started up the engine ... still the loud tapping sound ... i took the valve cover off (knowing that oil would spray every where) and started the engine again because i wanted to be sure it wasn't a rocker hitting the cover ... still the same noise
it sounds like the noise is coming from the rocker assembly near the rear of the engine do you think i need to rebuild the cam shaft/rocker assembly? could it be a valve? any ideas on how to deduce where the problem is coming from? i can't keep the engine running for more than a few seconds because of the oil spray thanks
__________________
#9 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
any chance that getting hung up caused the exhaust to get damaged, maybe a broken manifold stud at the rear of the head?
it is a loud tapping like sound, and not a harder 'knock', right?
__________________
Quote:
Insomnia: it's a way of life.
#10 (permalink) |
hmmm ... i thought about that ... that it could be exhaust ... but the noise seems more like metallic tapping ... but i will go check that right now ... thanks abecedarian
__________________
#11 (permalink) | |
an exhaust leak around the exhaust port can sound like someone tapping on a thin piece of sheet metal with the tip of a long screwdriver or pencil tip
__________________
#12 (permalink) |
ok, i checked the exhaust from the block to the cat and every looks ok
i just took some video of the engine running and will post once i finish processing it also, the engine dies even though the idle is strong and smooth, it's like there is some resistance somewhere once again, still does it with the valve cover off i'm thinking that it may be down near the flywheel now thanks for the replies everyone, i would love to get this fixed tonight so that i can finally go home, and be back for the holiday weekend
__________________
#13 (permalink) | |||
Video Posted
Video of loud tapping noise with engine running (does the same thing with valve cover removed):
__________________
The Jungle Runner 88 4runner, 22re, 2" 4crawler body lift, custom aluminum interior panels and lock box, Downey Air Intake, Procomp 31x10.5 M/T Tires, My 1st Yota 4x4, purchased March 07 My business: ProgressiveApps.com Last edited by jungle_runner; 07-03-2009 at 05:01 PM. |
#14 (permalink) |
ok, now i'm kind of thinking that it is an exhaust leak because i see exhaust coming out near the manifold
would the lack of back pressure cause the engine to die when at low idle? thanks
__________________
#15 (permalink) |
This sounds like one of my farm tractors...with an exhaust leak.
Hmmm...
__________________
1990 4runner SR5 3.0 (3vz-e) All options. Bone stock. Automatic w/overdrive and cruise control. 232,000 miles. Oil pump replaced @ 186,000,head gaskets at 188,000. 15-17mpg. My girls.Lisse' & Jessi http://i293.photobucket.com/albums/m...SC00714200.jpg I AM LOOKING FOR THESE PART:Front passenger,inner fender.http://i293.photobucket.com/albums/m...00outlined.jpg MW 1990 Toyota 4Runner 4DR Road Test http://www.youtube.com/watch?v=bYTHIa6RNRA |
#16 (permalink) |
yep, definitely an exhaust leak ... i tighten up the bolts near the rear of the exhaust manifold and the noise has dramatically reduced ... wow! now i know (and you know (for the other noobs)) what an exhaust leak can sound like, thanks every one
i still would like to know if an exhaust leak (not having enough back pressure) would cause the engine to die? ... i just want to be sure that this is what is probably causing that to happen ... my intuition says yes, but i'd like a second opinion thanks
__________________
#17 (permalink) | |
overall, no, an exhaust leak won't cause the engine to die.
but since you've had valve cover issues, I'd venture enough to guess that you've got a leak around the valve cover causing a rather large vacuum leak (no, don't go reading the 'oil cap removed' thread... ). since the PCV system requires a sealed crank case to operate properly, if the valve cover isn't sealed properly it will present itself as a major vacuum leak and can cause engine driveability issues such as stalling at idle and lean mixtures.
__________________
#18 (permalink) |
it's 4am, i've been working on my truck since 11am this morning and have been putting in 6 or more hours every day for the last week ... i really need to get this done ... here's the update:
ran to autozone and picked up a new manifold gasket, flange rings, and the red silicone sealant ... even though one bolt into the head seems to be stripped, the exhaust leak is now audibly gone, no tapping noise ... i figure that the jolt to the frame on the concrete broke loose the gasket's seal on the manifold ... upon inspection, it was a very old, cracked gasket i probably mentioned before that the timing guides were broken as well (don't know how long that had been broken or if it happened at the same time as the exhaust leak), so new guides, chain, gears, tensioner, and gaskets have all been installed the engine started stalling at idle as soon as the exhaust leak started making it's noise, but now, with the exhaust leak fixed, the engine is still stalling at idle and sputtering at higher rpms timing off? lost compression? some sensor that also simultaneously went bad during the jolt? timing? the light links of the timing chain are matched up with the dimple on cam gear and crank gear, tried distributor one tooth advanced and retarded, but the original location runs best lost compression? it looks like all my vacuum lines are in place. i did remove the a/c compressor and it's radiator while i was taking apart the front end, and i don't plan to put them back in a sensor malfunctioning? o2? afm? tps? egr? could any of these cause the engine to stall at idle? thanks in advance for any ideas ... my eyelids are heavy ... got to z zzz zz zz z zzz
__________________
#19 (permalink) |
thanks for the idea, would you still guess this knowing that the stalling started simultaneously with the exhaust leak? could the valve cover have shifted and began to loose compression?
__________________
#20 (permalink) |
i'm going to try spraying carb cleaner around the engine to see if there are any open areas on the intake side ... maybe the intake gasket is cracked like the exhaust was
__________________
#21 (permalink) |
also, there is white smoke coming from the engine on the exhaust side ... i thought it may just be the white lithium lube i used in the oil pump burning off, but it is staying pretty consistent, especially when the engine is rev'd ... the white smoke is coming out of the tail pipe too
also, if i press the gas pedal and hold it at a constant position ... the engine revs but then tappers off until it dies ... it's like i have to keep pumping it to keep the engine going ... once it warms up, i can hold it at a constant rpm off to get some carb cleaner
__________________
#22 (permalink) |
Staff
Video sounded like you had a little toyota diesel in there lol...
maybe you could post another quick video showing the leak smoke you're talking about?
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#23 (permalink) |
pulled the codes, just getting 51 ... now let me see what that is ... google search says TPS ...
i noticed on 4crawler's page a post that mentions that can cause poor idle, engine stall, and inability to set timing ... maybe the jolt through that out of wack too
__________________
The Jungle Runner 88 4runner, 22re, 2" 4crawler body lift, custom aluminum interior panels and lock box, Downey Air Intake, Procomp 31x10.5 M/T Tires, My 1st Yota 4x4, purchased March 07 My business: ProgressiveApps.com Last edited by jungle_runner; 07-04-2009 at 12:05 PM. |
#24 (permalink) |
Urban wheeling FOR THE WIN!!!! Lockers help
__________________
. . . I said lie, for me lying under a process tree . . . . |
#25 (permalink) |
started testing the TPS using the guidelines provided here: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
but i am getting an open circuit (1) on the first test with the throttle all the way closed ... the ohm meter gives a reading for a split second (varying between 70 to 150 ohms) and then just shows 1 ... here is the settings i am using on the ohm meter (it's set at 200): ![]() when i change to a different setting such as 2k or 20k i get decimal read outs such as .534, i believe that 200 is the right reading range since i am looking for a ohm reading of 200-800 for the first test so is my TPS completely bad? i'm getting diagnostic code 51 do i need a new one or can this one be serviced? thanks
__________________
| Tags |
| belt, block, bottom, concrete, cover, damaged, drove, engine, extremely, install, loud, noise, plastic, tapping, timing |
