Done with 3.0 vze Rebuild but Have Extra Hose
Old 12-30-2011, 01:58 PM
offdalip's Avatar
I finished a HG change and am done and have an extra hose coming up next to the water bypass outlet behind the intake. It branches off the same pipe as the hose next to it (see photo at link below). There is also an outlet on the top of the throttle body which I am not sure if a hose is supposed to connect to it. but the hose in question does not reach the throttle body. Should have took an extra photo before dismantling. Any help would be appreciated as I am ready to fire it up!
http://www.offdalip.com/hose.jpg
Old 12-30-2011, 02:09 PM
rattlewagon's Avatar
I think it goes to the bottom of the throttlebody?
Old 12-30-2011, 03:01 PM
offdalip's Avatar
Yes!! Thanks Rattlewagon. How about that open port on the top of the throttlebody? OK as is?
Old 12-30-2011, 03:16 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The coolant hose goes to the bottom/right of the throttle at the idle air control valve. You'll see the barb down below the throttle sensor.
The port on top of the throttle looks like it has a cap on it. Are you sure that it's open? If it's capped off, leave it. It doesn't do anything. Not really sure why it's there, but mine's the same way. I figured it was for an option my vehicle....and apparently yours.... didn't have. If it's open, though, cap it. There's cheap vacuum cap kits at most auto part stores.
Old 12-30-2011, 03:17 PM
rworegon's Avatar
Looks like a factory cap on that port so most likely nothing is attached to it.
Old 12-30-2011, 04:19 PM
offdalip's Avatar
Yes it that is a cap not a port now that I look closer, thanks guys!!
Alex Bessinger
08-31-2015 09:17 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
the1998sr5
07-16-2015 06:20 AM
Fundy Rider
07-16-2015 01:35 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: Done with 3.0 vze Rebuild but Have Extra Hose
