Disconnecting tranny lines from radiator.
Reassembling engine after head gasket replacement.3.0 v-6.I want to remove radiator to get to the crankshaft pulley and number 1 timing cover so I can replace timing belt.My last step.I have an automatic tranny with two lines running to the radiator.I need to disconnect them to remove radiator,should I put plugs in the lines to prevent all the tranny fluid from leaking out?Or let it drain and refill it.I was always under the impression you never let youre automatic tranny run dry as you can never really get it properly full again.Thanx
That was quick
You know thats what I was gonna do and have done before but I wanted a second opinion.Yours is good enough for me bro,thanx.This forum rocks.
JaredL
03-28-2016 09:08 PM
Iceman4193
07-15-2015 04:48 PM
TokyoD23
07-12-2015 06:01 AM
