Coolant temperature switch?..
Old 10-26-2009, 09:16 PM
HAWAIIANSTYLE's Avatar
accidentally broke the coolant temperature switch as i was putting the plenum back in place...went to autozone and got a new one. it broke off the wiring clip so i ended up having to crimp on another clip... so now after the change,.. at cold start the temperature needle quickly jumps to the hot side. doesnt stay at the middle like it should and constanly moves back and forth. please help?
Old 10-26-2009, 09:28 PM
crawlerjunkie's Avatar
Bad connection?
Old 10-27-2009, 08:00 AM
must be some weird SR5 thing then.
Old 10-27-2009, 08:30 AM
swampfox's Avatar
IF you used thread tape, when you installed the sensor it could effect the grounding.
Old 10-27-2009, 03:00 PM
abecedarian's Avatar
Did you put the ground lead back on the intake manifold?
Old 10-27-2009, 07:37 PM
yes i put the ground back. probably right on bad connection. i'll just leave it for now till the next time i need to get back there. thanks everyone
Old 10-27-2009, 07:42 PM
camo31_10.50's Avatar
yea...thats kind of an important component there bud....just check everything before you drive it..you never can tell when its going to overheat...and THAT thing is what tells ya it is..lol
Old 10-27-2009, 08:29 PM
Windsor's Avatar
I doubt it, especially for a coolant-related sender/switch.
Old 10-27-2009, 09:29 PM
Why doubt it? Thread sealing tape (teflon for instance) is not electrically conductive and since the coolant temp sender is single wire and grounds through the manifold, tape could insulate the sender resulting in erratic readings.
Old 10-28-2009, 08:21 AM
Windsor's Avatar
because coolant conducts electricity.
Old 10-28-2009, 08:31 AM
Yes, it can, but with much higher resistance than metal. Additionally, coolant has additives designed to reduce conductivity in order to reduce electrolysis of the dissimilar metals of the head (aluminum), block (iron) and radiator (copper).
Old 10-28-2009, 08:47 AM
Windsor's Avatar
bah!
I've never had a problem using teflon tape on sending units, but then again I only put one layer on the threads. ISTR the FSM saying to use it, also.
Testing whether your teflon tape is inhibiting electrons is easy, just measure the resistance between the shell of the sender/switch and the block.
But here's my original point...
If you use enough teflon tape to completely isolate the sending unit from the block, you're doing it wrong.
When was the last time you backed something out that had teflon tape and the tape was still 100% intact?
Blamalam
03-12-2022 07:34 AM
JaredL
03-28-2016 09:08 PM
Tacoma1313
08-17-2015 05:44 PM
JHalcyonM
08-04-2015 01:19 PM
Logz808
07-26-2015 07:09 AM
Quick Reply: Coolant temperature switch?..
