Coolant temp sensor? Temp Questions..
The one in front of the manifold next to the cold start is for the ECU.
The one for the gauge is in the middle of the manifold (front to rear).
Lower plenum, on top. It's close to the valve cover.
Note, don't test your gauge by shorting the connector straight to ground. That's a great way to drive too much current through it and damage your gauge. Do it through a test lead or test light, which will limit the current.
#25
The sender is on top of the intake dead center, but down in there with the fuel rail. One wire comes out of there. The two on the front are for the ECU and CSI timer with two wires. Use the test light on these.
the1998sr5
15
07-14-2020 08:35 PM
Poncho0206
07-10-2015 06:21 PM
1988, 22re, bad, chevy, cold, coolant, coolantover, sender, sending, sensor, temp, temperature, tempsender, test, thermostsat, toyota, unit, water
