Coolant temp sensor broke
i was trying to install a new coolant temp sensor in my 94 runner but as i was removing the old one, it broke. the threads of the old sensor is stuck in the housing. how do i get the threads out so i can put the new sensor in?
I got a 86 4x4...22re..! Where is the coolant temp sensor located???? Be having a heck of a time with overheating problems! New head last summer, new thermostat, new clutch fan, brand new radiator....water pump working fine! Coolant temp sensor last option! wheres it located?
Thanks
wilywin@aol.com
Thanks
wilywin@aol.com
whats the other sensor? (left) ? Also...not to sound dumb and obvious, but how can you tell if that sensor is bad? What goes wrong on the truck when it goes bad? I am having some overheating problems and have replaced everything under the sun! New head, rv cam, timing set, clutch fan, radiator, thermostat. Thing still gets hot??? And the gauge only seems to work speradically!
Thanks
Thanks
The black plug is the cold start injector time switch.The wires on these sensors and switches are often very brittle.My temp sensor wires broke two different times on my 86 truck,As far as the overheating,I don't have a clue.Someone on this board will know.
nframe
3.4 Swaps
08-16-2015 09:03 AM
Poncho0206
07-10-2015 06:21 PM
