Coolant switch
Old 02-05-2011, 02:09 PM
weaselman's Avatar
Coolant switch
so these are coolant temp sensors? NOT for the gauge inside the truck, that one is lower on the intake..
what size threads are these? i installed an electric fan on my truck and need to get an in water switch, so the fan will turn on, the probe type switch isnt coming on when needed. doesnt matter where i put it.
so i need to know what size threads so i can buy a switch and put in there.
Old 02-05-2011, 02:32 PM
xxxtreme22r's Avatar
you realize some of those coolant temp switches are required for the ECU to function properly and you can't just remove them right?
Old 02-05-2011, 02:40 PM
corax's Avatar
The one with the spade terminal (nearest to the front) isn't factory. It looks like the same one I run, and if it is, it will be 3/8" NPT
Check this thread for some info I posted up about putting a coolant switch on a 22RE
Old 02-05-2011, 03:18 PM
weaselman's Avatar
i never said i was going to remove them. i am going to get a t fitting and have them both.
Old 02-06-2011, 07:15 AM
corax's Avatar
So what is the aft mkt one with the spade connector for in your picture?
Old 02-06-2011, 06:55 PM
weaselman's Avatar
thats how it was when i bought the truck, but its thermo switch one and thermo switch 2 according to the factory service manual. i think.
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
JaredL
03-28-2016 09:08 PM
rjtrials
08-06-2015 07:25 PM
JHalcyonM
08-04-2015 01:19 PM
Quick Reply: Coolant switch
