| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Code 25- Please help diagnose
#2 (permalink) |
i've had the same issue for like 9 months and I replaced all the same things... But I did notice I had cracks in the air hoses behind the air filter. I replaced that and I had a HUGE jump in power
#3 (permalink) |
i wonder if there's any way of inspecting the hoses besides visually. for example squirting the hoses with a spray bottle and check for any changes in engine speed
#4 (permalink) |
Someone said spray with starter fluid, but I thought it was easier just to take them off and clean and inspect them
#5 (permalink) |
Ok back from outside, btw it is f@#kin cold out there, took apart the intake piping for inspection and low and behold there was a crack on the lip of the hose that connects to the throttle body. So as a temp. fix I wrapped the lip with a crapload of electrical tape to cover that crack. Reattached, cleared the cel and test drove it around the block. I did not get any light (still have to drive it a longer distance) and the hesitation has decreased significantly, although not fully. Hopefully that was the issue it was having. Although perhaps I should swap the O2 sensor as its outlived its useful life.
btw, thanks lemons Last edited by CILO; 01-17-2007 at 10:19 AM. |
#6 (permalink) |
Well it appears the intake wasnt the issue. problem arose again the next day. went back out this past weekend and checked/replaced all my plugs, no oil or residue on cyl#6 (thank God) all my plugs were way off ( .037 to .042). this cured my slight stumble when gassing it right after starting. The engine runs well for a while and then the idle goes down to about 500 to 600 when stopped and in drive (automatic). so it seems the problem starts when the engine is fully warm.
Question: How hard would it be to test the fuel pressure and what tools are needed? Also, would testing out the o2 sensor via the diagnostic port indicate if there's a problem with my o2sensor? Last edited by CILO; 01-22-2007 at 08:46 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Trouble code 25 - Please help | beaker | 86-95 Trucks & 4Runners | 6 | 05-14-2008 06:32 AM |
| Code 25 and Code 26 | Viet0ne | 86-95 Trucks & 4Runners | 16 | 10-21-2007 07:32 PM |
| Code 25 questions | mr_lemons | 86-95 Trucks & 4Runners | 9 | 06-19-2007 04:50 PM |
| 94 Toyota 4WD - Code 71 / Code 25 | mmunoa | 86-95 Trucks & 4Runners | 2 | 02-22-2006 06:50 PM |
| What causes Code 25 (Lean)? | TRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-15-2004 02:21 PM |
