code 25- pair system?
Old Nov 18, 2007 | 12:58 PM
screamer76's Avatar
where to start? i have a 95 3.0 5spd 4wd non-cali 4runner with(according to the odometer) 106,000. i failed emissions yesterday with slightly high hc
in the drive portion of the test. the cat and egr modulator were replaced right before i bought it in july of 06(93,000 at the time)and it passed
emissions the day i got it. i had code 71 almost immediately after buying it, and found that all of the metal vacuum rails for the egr system were
corroded so badly on the inside that they were totally obstructed. i bypassed them with new longer rubber vacuum lines and cleaned out the ports on
the throttle body and vsv and code 71 went away. i'm pretty sure they replaced the modulator for nothing. soon after that i recieved code 25. i have
replaced every vacuum line except the 4wd and power steering and some of the larger odd sized ones and i'm fairly certain none of those are leaking. i
tested the fuel pressure(had to buy the fuel pressure tester and a multimeter and a vacuum pump and i can't remember wtf else to do all of this stuff,
but it seemed like a better investment than the EIGHTY DOLLARS AN HOUR that the shop by my work wanted for diagnostic. i can't afford ten an hour
with the screeching halt in the housing industry) which came up too high, and replaced the fuel pressure regulator. fuel pressure seemed right in the
second i had to look before my stupid actron tester started spraying gas everywhere from the dial. what had been a high idle then became a low idle
with stalling soon after cold engine starting. actually on cold engine starting the idle would raise and lower from about 500 to around 850 then slowly
that would taper off to a steady 5 or 6. it did the fluctuating idle thing before the regulator was replaced, but it went from 800 to 1200 and would
eventually sit around 12. i adjusted the idle scew out as far it would go with no signifigant change and felt that i had to adjust the throttle cable to
temporarily compensate. hopefully that wasn't a huge mistake, but i'm new to efi and didn't know what else to do. spark plugs have been changed
twice now and show supporting evidence of the lean malfunction. coil seems good. distributor has proper resistance. the wires and cap were also
replaced when i got it so they are about a year and a half old now. i hooked up an inductive timing light to each wire, including the coil and verified
spark. i tested the air flow meter for resistance and it seems to also be okay. i replaced the water temp sensor because i broke the old one trying to
remove it for testing. i tested each individual injector, the cold start time switch and injector, and the o2 sensor all for resistance, nothing. i haven't
seen any suspect wires or connections to any of these parts. yesterday after failing i tried to have the injectors flushed and that doesn't seem to
have changed anything. lately i've noticed that i can actually hear over the running engine air coming out of the filter for the pair system vsv. is it
possible that too much air is coming out of the filter? it seems really loud considering that i never notice it from the other vsv's surrounding it. i saw in
my factory manual that the pair system partially controls hc content. is it possible to switch that vsv with one of the ones from my 4wd with the
same electrical connector for the purpose of diagnosing it? it certainly looks the same but wtf do i know? any advice from someone who knows their
s%#t would be so very greatly appreciated. i have six weeks until my tags go bad, and no money for error.
Old Nov 18, 2007 | 04:22 PM
Targetnut's Avatar
code 25 fuel system lean is triggered when the O2 sensor output voltage remains to low even after correction by the ECM this can be caused by air leaks any where in the intake tract low fuel pressure dirty injectors misfires caused by secondary ignition components malfunctioning sensors coolant temp sensor, airflow sensor this also includes the O2 sensor. It is not uncommon for a failing O2 sensor to trip a code 25
And please,
use punctuation and break up your post so that it is not so hard to read
like this:
code 25, fuel system lean is triggered when the O2 sensor output voltage remains to low even after correction by the ECM.
this can be caused by air leaks any where in the intake tract.
low fuel pressure.
dirty injectors.
Old Nov 18, 2007 | 05:40 PM
screamer76's Avatar
And please,
like this:
low fuel pressure.
dirty injectors.
Ok. Sry about that. Still new to this. Maybe i'll try just buying a new oxygen
sensor, but first i'd like to try swapping my pair vsv for one of the ones for my
fwd. They have the same type of connection and the vacuum lines and filter
are in the same locations. I'm just nervous about doing it. Does anyone know
the vsv's that i'm referring to?
montanatruck
Feb 26, 2017 07:07 AM
A2theK
Jan 10, 2016 10:18 AM
raptor510
Aug 19, 2015 02:15 PM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
