clutch problem please help
Old 10-14-2011, 09:49 AM
davidmerrow's Avatar
the clutch peddle in my 90 pickup will not come up from the floor unless i manually pull it up, i replaced the clucth master and slave cylinders and bled the system but still nothing i was wondering if anyone else has had this problem or if the throw out bearing could be causing the issue? thanks alot
Old 10-14-2011, 10:26 AM
skjos's Avatar
Is the spring that returns the pedal after it has been pressed broken or disconnected?
Old 10-14-2011, 08:25 PM
Jkelley429's Avatar
check the clutch pedal bracket that the pedal mounts to. it could be cracked causing the pedal not to return to place. are you having any shifting problems?
the1998sr5
15
07-14-2020 08:35 PM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
the1998sr5
07-16-2015 06:20 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: clutch problem please help
