Clutch hydraulics rubber hose
Old 05-06-2014, 06:55 PM
bobjohnson2121's Avatar
Hi all,
This morning my clutch pedal went to the floor and wouldn't return. Found my clutch master cylinder empty and traced the leak to the rubber hose on the passenger side which connects the metal hose from the master cylinder and the metal hose leading to the slave.
Any idea what this part is called, and maybe a good website for yota parts? It's. 92 truck by the way.
Thanks!
Old 05-06-2014, 08:17 PM
BigBluePile's Avatar
Yes.
Marlin Crawler.
Old 05-06-2014, 11:16 PM
wyoming9's Avatar
Red face
Yes
Rock Auto
You can get the hose almost any place .
If the hose died of old age perhaps time to replace the rest of the Hydraulic parts as well.
Old 05-07-2014, 12:41 AM
frm_808's Avatar
Originally Posted by bigbluepile
yes.
Marlin crawler.
Originally Posted by wyoming9
yes
rock auto
you can get the hose almost any place .
If the hose died of old age perhaps time to replace the rest of the hydraulic parts as well.
agreed
Old 05-07-2014, 04:10 AM
RustBucket's Avatar
I used this Dorman part, works great for only $13 shipped:
Amazon.com: Dorman H38228 Hydraulic Clutch Hose: Automotive Amazon.com: Dorman H38228 Hydraulic Clutch Hose: Automotive
Old 05-07-2014, 09:04 AM
Thanks for the replies guys... I did some googling right after posting, and found the part easy. I didn't think I'd be able to find it simply by searching "clutch hydraulic hose". Figured it had some more complicated name.
RustBucket... That's the one I bought, the Dorman one. Only for $15 more!
By the way, I assume the Clutch bleader will be easy to find? Somewhere near the slave cylinder?
Old 05-07-2014, 10:29 AM
nothingbetter's Avatar
yup, you'll see it when you're changing the hose. I suggest making sure it isn't seized before you install the hose. If it breaks off it will be easier to remove on a bench rather than on the truck.
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
Iceman4193
08-28-2015 08:43 PM
the1998sr5
07-16-2015 06:20 AM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: Clutch hydraulics rubber hose
