clutch fan may be going out?
Old 09-18-2006, 07:09 PM
weakyota91's Avatar
ok so i started up my truck this morning and a awful grinding noise came from one of the pulleys. (3.0 v.6)170000 miles. Took off belts alternator pulley seems to be fine the two big pulleys behind the fan seem to be tight. the only thing left i can think of the begin replacing mite be the clutch fan. as the engine runs it just sounds like metat to metal grinding mabye bearing are going out? If it is the cluth fan and it decides to go out before i get it replaced will the fan just freeze up stop turning or is there a chance it will explode destoying my radiator or other things?
Old 09-18-2006, 07:42 PM
leiniesred's Avatar
Might be the fan idler pulley, not the clutch.
another loud pully is the A/C tensioner (if you have A/C)
My fan idler pully (Toyota calls it a "fan bracket") (Some call it a "fake water pump") was ready to fail at 256,000. Toyota will only sell the assembly with the clutch and fan $500 bucks. Yeah right. E-bay has the lowest price. NAPA can get the unit too.
I just cut it off flush and switched to an electric Ford 2-speed fan instead.
Old 09-19-2006, 07:23 PM
weakyota91's Avatar
found out what it was its the stupid bearing on the end of my water pump bracket. $286 for parts
Old 09-20-2006, 12:32 AM
Elton's Avatar
ouch gotta love the insane price for parts for the 3.0
Old 09-30-2006, 07:00 PM
mtnfreak's Avatar
Quick ? for ya Weak - was it the part driven by the timing belt or the one driven by the accessory belts (alt., p/s, a/c)?
Quick ? for Red - do you know if NAPA can get just the bracket w/o the fan & clutch? I'm having enough trouble convincing them that it's not the water pump.
Thanks.
Old 03-09-2012, 05:53 PM
One1991SR5V64X4's Avatar
Its called The Fan Bracket Pulley.
lol. Depends .
Old 03-09-2012, 06:35 PM
justin_4runner's Avatar
hey the answer came 6 yrs later.... sweet... hahaha
Old 03-09-2012, 07:49 PM
Fan Clutch
lol. iknow, but thought it may help others in the future. especially regarding the Auto parts supp"liers sending people parts that dont fit & or work properly for that application.
Longbed 90
03-11-2019 12:38 PM
runnermedic
13
09-21-2015 05:20 PM
sonorn67
09-19-2015 05:39 PM
noahstancik
09-10-2015 10:47 AM
Aaron Logan
09-03-2015 08:08 AM
Quick Reply: clutch fan may be going out?
