Cig. Lighter question.
Old 02-22-2010, 12:28 PM
camo31_10.50's Avatar
okay so since my speedometer cables keep getting burned in half because of my header, and i have a Garmin GPS, i decided to TRY and fix my cig. lighter in the '86 so i can see how fast i'm going and my mileage...
so i hooked it up, with the spade connector and the little round one, put a fuse in the slot marked "CIG LIGHTER" (15amp just like it says i beleive) and plug up my GPS and.....NOTHING..wtf? lol
the cig lighter came from the junkyard, but i'm assuming the cig lighter itself can't go bad?
would i be able to wire it just straight to the battery for constant 12v power? if so which wire is hot and ground? (i'm guessing the round plug is hot and the spade connector is ground?)
thanks for the help with the simple questions LOL
Old 02-22-2010, 12:57 PM
qdude79's Avatar
Yeah, you could wire it straight. Mine's wired like that right now so I can run something without having the ignition on. Better fuse it, though.
Yes, the lighter receptacles themselves can break/lose connection with the little jumpers at the back of 'em. I soldered mine up good so I could run my electric blanket all night. Look at the back and I think you'll see what I mean.
Old 02-22-2010, 01:00 PM
i'll check it out a little closer, i had it apart just a min ago lol
i'll prolly just run it straight, i can fuse it pretty easily lol
Old 02-22-2010, 01:41 PM
zachw90's Avatar
check the fusible link on the back of the actual cig lighter
-It is a little tiny wire that could have gotten burned out
Old 02-22-2010, 04:18 PM
i took the outlet apart and cleaned all of the rust and such off of it, plugged it all back up..plugged up my GPS and BOOM! it works lol
guess it just took some cleaning lol
Old 02-23-2010, 12:04 AM
stormin94's Avatar
Lol. Thanks for reminding me, that's one thing that's never worked on my rig either. What guage wire should be used, and what amp fuse....I want it to be able to handle more amps/watts than stock too, so....
Old 02-23-2010, 06:11 AM
hunter4runner's Avatar
12 gauge to be safe and 15 amp fuse (whatever is in the fuse box)
Redeth005
06-28-2018 08:16 PM
Chicken12
10-14-2015 03:54 PM
JUICE222
10-13-2015 08:50 AM
viesail
09-21-2015 06:00 AM
reallynotamechanic
09-20-2015 05:40 PM
Quick Reply: Cig. Lighter question.
