Checking for codes - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-09-2007, 04:49 PM   #1 (permalink)
Robrt32's Avatar
Checking for codes
After this seafoam i'm doing i'm gonna change spark plugs and i wanna check for codes.. I have never done this on any car or truck.. I understand how to use the paper clip but which ones do i stick it in? I'm not the brightest person when comes to anything electrical , can someone break the procedure down into redneck terms for me?
__________________
1992 ext.cab truck 2 wheel drive..22 RE
Robrt32 is offline
Old 06-09-2007, 05:25 PM   #2 (permalink)
MudHippy's Avatar
I couldn't explain it any better than the FSM. Basically, your going to short 2 connectors(TE & E) with a wire(paperclip,etc.) and observe a series of flashes of the "check engine" light. Then refer to the list of trouble codes to find which code that number is. You'll figure it out.
Example: flash flash(pause)flash=21, flash(pause)flash flash flash flash=14
You can have many codes consecutively, so it might be confusing at first to seperate one from another, but the series will loop continously untill either unshorting the connectors or clearing the system memory of stored codes(described in the FSM).
93 FSM 22RE MFI System-Diagnostics page http://personal.utulsa.edu/~nathan-b...26diagnosi.pdf
__________________
Sonoran Steel Early IFS Truss
Your IFS is SPINELESS without it
SonoranSteel.com
I'm Cuckoo For YOTA Trucks!
MudHippy is offline
Old 06-09-2007, 05:51 PM   #3 (permalink)
Sonofmayhem's Avatar
There should be a diagnostic box on your engine fuse box. You open the little box and if you are on the pass. fender you plug the middle and top left corner with the clip ON the first set of six connectors.
__________________
4.3/5.0 Do iT!
Sonofmayhem is offline
Old 06-09-2007, 06:17 PM   #4 (permalink)
Robrt32's Avatar
So i short it out, sit down in the truck and trun the key on and count flashes....seems easy enough.. I will give it a try in the morning, skeeters will eat you alive out there now
__________________
Robrt32 is offline
Old 06-09-2007, 08:30 PM   #5 (permalink)
mudhippy - Do you have the entire FSM in pdf format? I have a 95 4Runner and would love to get all the chapters if possible.
Thanks,
DrA>
DrAnonymous is offline
Old 06-09-2007, 08:59 PM   #6 (permalink)
MudHippy's Avatar
You betcha. Copy these.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
The other freebies.
http://www.ncttora.com/fsm/index.html Right click, then "save target as" to download these.
__________________
SonoranSteel.com
MudHippy is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Checking Codes on a 91 4runner? Fo by Fo 86-95 Trucks & 4Runners 30 12-04-2006 08:15 PM
Help Check Engine Cel codes Trans codes Brake codes NicksBlue934runner 86-95 Trucks & 4Runners 2 04-26-2006 05:35 AM
Checking codes on an 89? mtrdrms 86-95 Trucks & 4Runners 1 04-03-2006 02:03 PM
checking trouble codes Robinhood150 Maintenance & Repair Archives 1 06-15-2002 01:58 PM
2009 InternetBrands, Inc.
