Chain or strap?
Old 11-05-2008, 02:30 PM
Junkers88's Avatar
Originally Posted by RobD
If you must join them, hook them over each other and insert a rolled up newspaper or magazine into the joint to keep them from becoming permanently joined.
Now that is a great idea! I never would have thought to use something in between them.
Old 11-05-2008, 02:32 PM
space-junk's Avatar
i have a strap that is rated for 110,000 lbs... i got it from my old job when i was an ironworker...
then i just got an aluminum reciever hitch that has a D ring built into it...
havent ever had to use it, but its there... i got a spare if anyone wants to buy it...
also, i dont carry a blanket, but i usually have a spare shirt in the back seat, so i just douse it with water and lay it over the strap... whiplash from a strap put a dent in my brother in laws 85 crawler...
Old 11-05-2008, 02:37 PM
Junkers88's Avatar
Originally Posted by Matt16
The reason why its not such a good idea to get the highest breaking strain possible is that you loose the bungee cord effect. Then its like running in to a brick wall when you take up the slack.
That reminds me of a guy in a little Bronco II (with lockers and 31 inch A/T's) that used to use a length of firehose that had been sewn into loops at the end. Down at the beach in Texas he'd pull up in front of a stuck rig, hook it up and leave some slack and then drive forward. Near the point where all the slack was gone he'd goose the throttle and then slam the brakes. The sudden "bungie" of the firehose would pull the stuck rig up and out about 2 feet. Just enough to get out of the hole. Then he'd collect his 20$ for pulling them out and go find another ding bat that got stuck. Guys were happy to pay him since the tow company that worked down there charged 100$ just to show up and take a look and then another 60$ to pull you to the street.
You'd be surprised how many people in 4x4's would hit the sand and once they started spinning would stand on the skinny pedal and get sunk. Of course telling them that steady throttle and aired down tires would prevent that usually fell on deaf/drunk ears.
Old 11-05-2008, 02:40 PM
Junkers88's Avatar
Originally Posted by a4runnerfreak
Shattered my friends kneecap, and shredded his leg bone. He has a prostetic leg now
God that hurts me just to think about......
Old 11-05-2008, 02:43 PM
  #25
Alex 400's Avatar
Originally Posted by littlecommando
but, straps can break, chains dont break
chains break, too. I have seen chains break and snap back rip through a guys rear window.
Old 11-05-2008, 02:46 PM
  #26
1986ToyTruckOMM's Avatar
Definitly a strap
Old 11-05-2008, 02:48 PM
  #27
coolthew's Avatar
yup, i've seen cable break.
like has been said before, strap. with no hooks, and get some recovery shackles. and definitely at least 20,000 lb test. i run a 30,000 test strap, and love it.
Old 11-05-2008, 02:59 PM
  #28
83 stump jumper's Avatar
Ya buy a strap, They dont break stuff
Old 11-05-2008, 03:01 PM
  #29
SR5
SR5's Avatar
Originally Posted by Alex 400
strap, but don't get some bs one that is only rated for like 8000, I snapped one like nothing at a mud pit a couple months ago. Get at least a 20,000 pound test strap. probably will not fail you.
you mean you snapped mine pulling me out
Old 11-05-2008, 03:03 PM
  #30
Sponsor
Tofer's Avatar
i have both... i use the strap for yanking trucks out when they are stuck, i use the chain for dragging deadfall trees back to camp.
Old 11-05-2008, 03:18 PM
  #31
coolthew's Avatar
thats true, chains definitely have their uses
Old 11-05-2008, 03:45 PM
  #32
JasonWin's Avatar
The only way I use chains is if I have a tire in between them to take out the bounce. Chains CAN BREAK and when they do, they're deadly. Straps are much safer. Unles you're hauling trees, then by all means use a chain. Round here we use belgians to tow trees
Old 11-05-2008, 05:35 PM
  #33
874runnersr5's Avatar
does anyone know how to get knots out of tow straps... somehow i got one in my good one and now i cant get it out!
Old 11-05-2008, 05:46 PM
  #34
Mic09dcsm's Avatar
Small screwdriver and a few minutes of your time.
I've yanked a truck so hard it bent my front tow hook and the strap was perfectly fine.
Old 11-05-2008, 06:12 PM
  #35
Alex 400's Avatar
hehehehe. yeah sorry bout that, you were really stuck though
Old 11-05-2008, 06:21 PM
  #36
Jay351's Avatar
Chains are great if your truck has 600hp. Then you just slowley load the chain (get rid of slack) and just giv'r!
Straps are great because they stretch when you reef on them. Usually helps to get the stuck truck out.
Its a problem when you use a chain like a strap...
Old 11-05-2008, 08:43 PM
  #37
91Toyota's Avatar
So your saying since I go through mud holes where my frame sits on the ground and all tires are off and I'm so stuck in my 2400lb little Toyota that my brother would actually use his Toyota pickup to even attempt to pull me out???
Sorry bud, but only reason I get stuck is because of loss of traction on something stupid. I NEVER need to yank...and a chain right now fits my bill way better. I WILL use the chain however for dragging crap if needed.
Old 11-05-2008, 08:49 PM
  #38
Sponsor
Tofer's Avatar
http://www.jackstoolshed.zoovy.com/p...&utm_campaign=
26 bucks...
i wheel my 2by as well, but always use straps when pulling trucks out. chains are for trees
Old 11-05-2008, 08:51 PM
  #39
i tried to, but i ended up to start cutting the rope
maybe il let it sit in some hot or cold water?
Old 11-05-2008, 09:11 PM
  #40
86tuning's Avatar
Take the knot out BEFORE you yank on it. Do you think you'll ever get a knot out of a strap after there's been TONS of force on it?
Quick Reply: Chain or strap?
