Catalytic converter relacement
I've got a few questions about replacing the cat myself rather than taking it to a shop.
What's the stock exhaust pipe size?
If the stock exhaust is 2", and I get a universal catalytic converter, which size input/output pipe will i need? And how do you clamp on a catalytic converter?
I got quoted by a shop around here for $200 to replace the cat. I'd like to try and do it myself and use that $200 for some other replacement, like the O2 sensors.
An OEM cat for my 95 pickup, 3.0 engine retails at over $900. I went with an aftermarket ($170) and it was about 1/3 the size of the one I replaced, it comes with a longer and adjustable pipe. Mine was easy to R&R, two nuts and bolts at each end and a clamp that came with the new cat. I soaked them for about three days with the home mix 50% acitone and 50% ATF.
If the $200 includes the cat, you won't save much by DIY.
I worry that I made a bad decision going with the aftermarket unit.
Harry
Harry
Harry
Harry
I think with my current cat, anything is better than what I have now. I see 2 kinds of cats: direct fit and universal. I'm looking at the universal magnaflow ones.
Magnaflow makes some pretty nice direct fit high flow cats. When i got mine 2 years ago it was $88 on ebay with free shipping. I took my old one to a scrap yard and got $150 for it lmao..fixed my exhaust leak and pocketd some cash! Theyre still on ebay but a little more money, mine had a part number of 23884 which is 105 shipped now. As long as you dont live in california you should be fine with the high flow. My truck actually is a cali emissions with an oxygen sensor after the cat and it did not trip a check engine light.
I cant use a direct fit. The previous owner sawed the old one off and looks like he welded a new one in place. So i don't have the fittings for the bolts for a direct fit cat.
I am currently trying to figure out if my cat is bad, I have failed the NOX portion of the california smog test. I have priced a few and if I need one will buy a magna flow direct fit for approx $185 at Kragens. Since some one has already butchered your pipes I would try and get some free advice from my local muffler shop as to what to do. Sounds like some welding may be involved
just buy a cheap cat and bring it to a shop and have them weld it in. A few weeks ago I picked up a walker cat from Advance for $70, it's a quality OEM replacement as far as I can tell.
I asked around, and most shops wont weld in an outside cat. has to be on from their inventory. Some BS about warranties or safety. I kind of agree. It's like bring your own steak to a resturaunt and asking the chef to cook it up without paying the $25 menu price/
any good exhaust shop will weld in a cat for you, it has nothing to do with warranties or safety, a catalytic converter is a catalytic converter, it's a pretty simple part, they just want to make money off you. I just had a local shop replace my downpipe and weld in a cat and an 02 sensor and bung that I brought in for $127 out the door. I guess if you want to pay more go ahead, I was just trying to help you save some money......
as to your steak analogy, if I brought my own steak would I be paying the chef to cook it (i.e. for his labor) or would I just be expecting I can sit down in his restauraunt and have him cook me a steak for free? Either way what you said about steaks makes no sense because that would never happen. On the other hand a good exhaust shop welding in a cat for someone for a fee is something that is very likely to happen and in my case and I'm sure many others has happened. At any rate I hope you get it worked out. Some people just like to pay more for things I guess.
I am currently trying to figure out if my cat is bad, I have failed the NOX portion of the california smog test. I have priced a few and if I need one will buy a magnaflow catalytic converter direct fit for approx $185 at Kragens. Since some one has already butchered your pipes I would try and get some free advice from my local muffler shop as to what to do. Sounds like some welding may be involved
kawazx636
10-06-2021 03:03 PM
Longbed 90
10-19-2015 11:05 AM
Cycles
09-29-2015 06:37 AM
Scotttekoch
09-28-2015 10:30 PM
