Bolt ID
Old 11-09-2016, 02:16 PM
Eighthnote's Avatar
Bolt ID
Hello all, I have a 1993 4x4 SR5. I have removed the passenger seat many times so my large lab is more comfortable laying or sitting on the floor rather than the seat. Over time these threads and bolts have become damaged. I'm searching to find what size bolts these are so I can go buy a tap and some new bolts. (4) bolts per seat. Any info would be appreciated.
Thank you,
Old 11-09-2016, 02:44 PM
robertd33's Avatar
idk about the threads, but i was going to suggest putting in studs with a pull pin to facilitate future seat removals.
Old 11-09-2016, 03:01 PM
Eighthnote's Avatar
I'm not 100% these part numbers are accurate but what I need are drawings or detailed descriptions.
90119-10381
90119-08442
Don't know why I was given two part numbers. All four bolts look and measure the same. 14 mm head and about 9.7 mm thread diameter. Although the threads are worn so the diameters may have started a little bigger. What I really need are the thread sizes and pitch. I need to re-tap the holes and replace the bolts.
Thank you,
Old 11-09-2016, 03:12 PM
85TRD4runner's Avatar
I'm pretty sure the thread pitch is 1.25
Toyota uses that thread pitch for almost all their hardware. If you want to be certain pull a seat bolt from the drivers side and go into a home depot or hardware store and use their "find a thread" board. Thats how I usually identify mystery bolts.
Old 11-09-2016, 10:09 PM
854x4's Avatar
Bolts are M10 x 1.25 I'm not sure on the length
Old 12-29-2018, 08:15 PM
mkivbren's Avatar
Anyone able to verify the above seat bolt p/n's? My dealer cant find on any of the diagrams. looking for the backside seat bolts.
