body panel question???
Old 09-26-2009, 08:52 PM
92_pickup_22re's Avatar
Question body panel question???
alright so here's my question! i have a 92 toyota pickup ext cab i'm pretty sure any 92 and 93 toyota 4runner fenders are identical to mine, now what i'm unsure of is, will the front grille and headlights bolt right up to my truck? i know the grille and headlights are different, but will they work besides redoing the wiring for the headlights? also will any front doors from a 92 or 93 4runner work on my 92 pickup as well??? would also like to know what years would work?? i'm assuming 86-95 years would work??? enlighten me if i'm wrong! thanks for all your help! you guys rock!
Old 09-26-2009, 09:18 PM
RobD's Avatar
Which headlights does your truck have, the sealed beam rectangulars or the flush fit ones?
Old 09-26-2009, 11:44 PM
Jay351's Avatar
so you want to swap in the 4runner composite headlights?
If you are doing so for looks, go for it. The rad support is a little different but it can all be swapped (92-95 4runner).
If you want better lighting, swap in some hella e-codes
Old 09-27-2009, 06:20 AM
yea, i have the rectangular sealed beam headlights right now!! i'm sure the headlights and grille could fit no problem, with some headlight harness modding, u say rad support too?? how much of a change is that?
Old 09-27-2009, 06:33 AM
RobD's Avatar
Like Jay said, you'll need to change core supports, too, which might be more headache than it's worth.
Are you doing it for looks or for the composite headlights?
Old 09-28-2009, 03:21 AM
Think I'll just keep it the way it is!! Lol can I get aftermarket headlights that use bulbs instead of replacing the whole headlight?? That I could put HID's in?
jasonty
41
12-23-2018 01:00 PM
coleypull15
11-03-2015 07:41 AM
GeoRoss
07-24-2015 03:03 PM
rushw
07-18-2015 01:46 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: body panel question???
