big oil leak on a 88 pickup 22re
Old 04-03-2010, 05:05 PM
92 TOY's Avatar
that's right.
and alot of gaskets if you order the head gasket kit....he has everything you need and then some.
Old 04-03-2010, 05:21 PM
Kiroshu's Avatar
Originally Posted by 92 TOY
let me tell ya, i took my crankshaft bolt off and just put it back on today without any air tools or really any special tool. i just posted on that thread today. i'll give you the link. i'm buttoning up my engine as we speak after doing a head gasket and timing chain and cover and oil and water pumps.
as a newbie with no experience this has been a formidable opponent, but definitely something you can do.
heres the link https://www.yotatech.com/forums/f116...emoval-193505/
This can be true if you put the truck in high gear(manaul trans) But if the bolt was was kinda easy to get off and relatively loose thats not good lol. That bolt needs to be tourqed down alot, I never tourqe em i just run them down with an impact and tey will be fine. But the 22r's tourqe for them is a lil over a 100 foot lbs i believe. You leave that bolt kinda loose you will beat up that key and spin that pulley on the crank and have a bad day.
Old 04-03-2010, 05:36 PM
oregon_yota's Avatar
yea the torque is about 130ft/lbs and i looked in my Haynes and it says, 5th gear 4Low and park brake on
Old 04-03-2010, 05:48 PM
92 TOY's Avatar
torque is 116.
i have an automatic, so there was no putting it in gear for me. my trick worked for me, that's all i can say....bolt DEFINITELY was not loose before or now.
Old 04-03-2010, 05:50 PM
  #25
would it be a good idea to replace the bolt?
Old 04-03-2010, 05:52 PM
  #26
92 TOY's Avatar
absolutely.
ordered mine from LC Engineering http://www.toyotacatalog.net/M1WebGe...C-9BDEFE32754A
Old 04-03-2010, 05:53 PM
  #27
Kiroshu's Avatar
Nah crank bolts are pretty stout and are hardly ever replaced
  #28
Kiroshu's Avatar
unless you rounded the head off ofcourse...
Old 04-03-2010, 05:56 PM
  #29
92 TOY's Avatar
like i did.
that's why it's important to use a 6 point impact socket, 1/2'' drive...broke some sockets and ratchet wrenches before i figured that out. was lucky to get it out.
Old 04-03-2010, 05:58 PM
  #30
Kiroshu's Avatar
hehe... indeed 6 point being the #1 choice for socket to bolt removal. The bolt should not be that much even though its a specialty bolt... i've never had to buy one before soo... I imagine it would be no more than 20 bucks
Old 04-03-2010, 06:02 PM
  #31
92 TOY's Avatar
click the link....$9.95...for my "freshening up" I ordered some of the odd stuff. crankshaft bolt, oil siphon gasket where it meets the block, oil pan washer(cuz I wanted to), and that long stupid allen bolt for through the lower intake...and an LCE sticker...all for about $14 to my door (I think), definitely less than $20.
KIROSHU read my bolt removal thread...I'm proud of myself.
Old 04-03-2010, 06:13 PM
  #32
Kiroshu's Avatar
Hehe good news.
Old 04-03-2010, 06:20 PM
  #33
92 TOY's Avatar
Yes, it was a victory for me, that and figuring out how to drop the pan (see the thread in my SIG)
Old 04-03-2010, 06:39 PM
  #34
Kiroshu's Avatar
If your talking about your oil pan removal you did a good job.
Old 04-03-2010, 06:40 PM
  #35
Kiroshu's Avatar
I had to do that once too and it was dreadful indeed...
Old 04-03-2010, 06:41 PM
  #36
92 TOY's Avatar
I'm psyched i found an easier way....well easier than taking all that other stuff apart....we'll see if it works out or if it's a fail....
Old 04-10-2010, 06:41 PM
  #37
well i got the timing chain kit from engnbldr, in about fours days too!
im starting my repair tomorrow so wish me luck haha
Old 04-10-2010, 06:48 PM
  #38
Kiroshu's Avatar
Good luck make sure you line everything up properly and don't forget about the "hidden" bolt under the Distrubutor drive gear for the t-cover. If you have done one on other cars you should know what to do relatively. Just like the other cars set it to TDC before taking it all apart and pull the Distrbutor straight out don't move it one bit. Lay it somewhere you know it won't get moved or touched ( that way you can just slide it back in there without any issue) and MARK IT before you pull it. Remeber Sprocket dots and bright chain links positons. Cam 12 o'clock/ Crank 6 o'clock
Old 04-11-2010, 12:56 PM
  #39
ok im down to the crank pulley bolt...roadblock...i need a 22mm socket to fit this and i've always heard its a 19
  #40
i dont know what the deal is with the two bolt heads. i was told it was a single 19 with an oversized flange
Quick Reply: big oil leak on a 88 pickup 22re
