Ball Joints
Old 05-18-2007, 11:05 AM
crazn's Avatar
Ball Joints
I just had my '92 4Runner serviced at Toyota for the steering relay rod recall. Now I was notified that my lower ball joints were worn and the upper ones have slight play. I don't know a lot about mechanics but could the old steering relay rod have caused the worn ball joints?
Old 05-18-2007, 11:19 AM
WCorbett's Avatar
they want you to pay them for needless work.
Old 05-18-2007, 12:00 PM
tombothetominator's Avatar
Always a possiblity, depending on the dealer. Of course, he might also need to look into replacing his balljoints...
Do some investigation yourself to see if you need to replace them or not.
Old 05-18-2007, 02:29 PM
elripster's Avatar
Ball joints wear from use. Our trucks have reached and are reaching the age where parts like those need replacing. Whether or not yours are actually bad enough to replace or the dealer just wants your dough is another story.
Frank
Old 05-18-2007, 08:38 PM
RustBucket's Avatar
There's a way to check if they are worn or not.
Jack up the front end and crank on the wheel to see if they have play in them. I think a Haynes manual will show you exactly how to determine that.
Slop in the steering can also be caused by worn BJs I think, I am going to change mine out sometime. They have 240k+ miles on them and lots of wheeling.
Old 05-19-2007, 08:31 AM
ewong's Avatar
Its super easy to check em on a lift
Was just at the garage getting a pre inspection check (i.e. lets see if the 4Runner - which has been in storage for 3-4 years - is in what kind of condition...)
Grab the wheel and pull/push look for play..
Its great to have a car repair shop that will work with you
[I have to cean and paint the frame... otherwise its should be GTG]
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: Ball Joints
