Back Window help
Old 11-10-2008, 05:15 AM
93toyrunner's Avatar
Back Window help
I searched and foud a lot of information about relay problems but that is not the problem my window does move up and down a little but usually I need to help it. I heard a little about using motors from different doors but I did not get a for sure answer. SO basically I am asking will the window motor from my old drivers work on my back door. Or could there be somthing else that weras out other than my relay.
Old 11-10-2008, 05:35 AM
leebee's Avatar
if you need to help the window up, then its more than likely in need of a motor. try contacting wabfab, he might have one ready to ship or check local used car yards for toyotas. strapp22 on here, might be able to assist with cross referencing other motor options.
lee
Old 11-10-2008, 08:09 AM
UKrunner's Avatar
Take off the trim on the inside of the door and lubricate all the runners and sliders and moving parts. You will be amazed at the difference it makes. When I got mine the glass was doing the same. I replaced the relays with not much success, then lubed everything and now it works like new.
Old 11-10-2008, 08:28 AM
Thanks this is more of the information I was looking for, but while I have it apart I may still stick my extra motor in there if it will work.
06-01-2021 01:51 PM
87blyota
07-10-2015 04:31 AM
colinmil
07-06-2015 04:03 PM
coryc85
07-06-2015 04:07 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: Back Window help
