Auto transmission wiring help needed
Old 12-06-2008, 04:53 PM
91diesel's Avatar
I have a diesel toyota motor and tranny. The tranny is a 340F I believe. Anyhow, I was changing the rear main seal on the motor and in the process pulled the wires out of a plug in the transmission. The plug is a black one with three wires located just above the transmission pan at the left rear. The plug isn't broken and I've disassembled it, but I need to know which wires go where. There is a purple/yellow, lght green, and a red/green wire. the plug is set up so that 2 wires are at the rear of the transmission and one towards the front in a triangle pattern. If someone can look on their truck and tell me which goes where, it would be much appreciated!
Old 12-06-2008, 08:38 PM
4runnerx3's Avatar
I think you are talking about the 1,2 shift solenoid wires and torque converter lock up solenoid wire.
94whiterunner
09-22-2015 07:25 PM
BigArt70
06-30-2015 09:51 PM
ACZR
06-23-2015 07:55 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Auto transmission wiring help needed
