Aussie Locker - Ease of install? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-29-2007, 10:49 AM   #1 (permalink)
RiNkY's Avatar
I'm no mechanic by any means - but I have replaced Alternators, Leaf Springs, Front Axles, Brakes, Shocks and a Tie Rod end of 2 in my time. Now I'm looking to throw an Aussie Locker in the rear of my 4Runner. How tough a job really is it for your average 'Weekend Mechanic' like they say on their site? Looks a little daunting to me removing the rear carrier etc. But I'm up for a bit of a challenge.
Or - is it best left to the pros?
__________________
RiNkY
87 4Runner (22re) 4x4 5spd. 1.5" BJ Spacers, 1" Diff Drop, WARN Manual Hubs, 2" Downey Leaf Springs, Skyjacker Shocks, 6" Wabfab shackles, Rear Shock Mounts & Bump Stops. Downey: Bikini Top & Sliders. Marlin Crawler Rear bumper. Budbuilt Crossmember. Addicted Offroad Front Bumper. 31x10.5's.
05 Xterra Off Road 4x4 6spd.
RiNkY is offline
Old 12-29-2007, 11:00 AM   #2 (permalink)
ovrrdrive's Avatar
I did mine (Lockright) and I'm about the same "mechanic" as you are. On a scale of 1-10 for the weekend warrior, I'd give it an 8. The actual work is more like a 5, but making sure everything is back the way it was before you took it apart makes me give the entire job an 8. If it isn't back the same as it was before you can ruin it.
If you do your homework and read everything you can on Zuk's gear page, mark everything, take your time and do it exactly the way they say to do it in the manual you'll be fine.
__________________
'95 xcab - SOLD
'03 4runner V8 SR5 completely stock
ovrrdrive is offline
Old 12-29-2007, 09:58 PM   #3 (permalink)
x2 on reading Zuk's pages.
It was fairly easy. Hardest part was getting the cross-pin dowel out. Don't go crazy on the grease to hold parts together as suggested by the instructions.
__________________
'87 DLX, E-Locker, Aussie, 30x9.50-15 Mesa CT(street) 34x9.50-15 TSL(trail), DougThorley Header....
Best Mod...Desert Pin-Striping (you can't buy that kind of work!)
hodgepodge79 is offline
Old 12-29-2007, 10:13 PM   #4 (permalink)
BLKNBLU's Avatar
I think it's a little misleading to say "basic tools" and "home mechanic". It sounds like I'm in the same category with you guys on skill. I did a Lockright but essentially the same procedure. I got it all apart and back together OK, but everything seemed loose and sloppy (and it was) Lucky for me I live 15 minutes from ZUK and I have another car. The issue I had was that the way they tell you to mark the adjusting rings only helps you in one dimension so you don't necessarily get them back exactly where they started from (at least with the lockright instructions) And you don't twist those adjusting rings with "basic tools". That said it isn't undoable. I think I'd be fine next time.
__________________
86 4Runner, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, rear Lockright, SAS w/ARB
My build thread. http://www.yotatech.com/f66/blknblu-s-sac-155872/
BLKNBLU is offline
Old 12-30-2007, 05:02 AM   #5 (permalink)
ovrrdrive's Avatar
Quote:
That's definitely true...
Lucky for me I had just gotten the 3rd from Zuk that I was installing in to so I knew the caps were over 100 ft lbs. After I finally figured out which thread they needed to be in I just tapped the cap back around to my mark and it's been fine.
By the way, Dad had an engraver on the shelf in his garage and I used that to mark everything. I marked every single piece I took off with the side and position that it came from. It saved my butt a few times too. I think a marker would have worn off of some of the pieces.
And btw, as much as Zuk hates it, I used a hammer and chisel to tighten the ring. I tried to make a tool but couldn't get it right and just tapped it tight. It worked fine but Zuk would get a nice chuckle out of it if he saw it...
__________________
'95 xcab - SOLD
Old 12-30-2007, 06:25 AM   #6 (permalink)
RiNkY's Avatar
Well it seems I am also within a few miles of the famous Zuk and my Runner is certainly not my daily driver, so I think I'll tackle it myself - then cry for help if needed
__________________
RiNkY
RiNkY is offline
Old 12-30-2007, 06:40 AM   #7 (permalink)
Bigblock's Avatar
Just do it clean ,dirt kills rear end bearings ,gears, seals.Block it up really good too.We dont want to hear about nobody getting smashed under his 4Runner!
Bigblock is offline
Old 12-30-2007, 03:01 PM   #8 (permalink)
BLKNBLU's Avatar
Quote:
That's perfect. As long as you don't need your truck back in a specific amount of time you should be fine. Good luck. You're gonna love being locked.
__________________
BLKNBLU is offline
Old 12-30-2007, 03:06 PM   #9 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
I installed a Lock-Right 1620 (V6) in the rear of my truck a few years back and it was actually easy. When it stopped locking a couple years ago I bought a new set of pins and springs and did it again. Still easy. That said I have never installed a 1610 (4 cyl).
__________________
DEPLOYED Again!
1994 SAS 2RZ/R151F=244:1!
1988 Toyota 4Runner SR5
seafarinman is offline
Old 12-30-2007, 03:31 PM   #10 (permalink)
black diamond's Avatar
i installed an aussie in my 4 cyl, piece of cake!! have patience and a clean work area.. u can do it!!!
black diamond is offline
Old 12-30-2007, 04:04 PM   #11 (permalink)
tortis's Avatar
mine was easy. i had ZUK(the mind reader) install them when he installed my 4:88 gears. ZUK is the master of diffs.
__________________
89 Truck X-tra Cab
LCE Timing Chain
31'' Maxxis Buckshot
4.88's built by ZUK(the mind reader)
Aussie Locker Front and Rear
63'' Chevy Springs
Marlin HD Clutch
Bilstein HD Shocks
2.5" Exhaust W/Dynomax Muffler
2-50 Watt Backup Lights
tortis is offline
Old 12-30-2007, 04:22 PM   #12 (permalink)
neilan's Avatar
i personally would take it in to zuk and let him tackle it. The diff is going to be a little sloppy in specs as bearings wear and such so why put in a locker and leave it like this. Its already out of the truck and its cheap insurance and longer life on the bearings and gears to have it all checked properly and everything adjusted..
__________________
DD: 87 4runner SR5, 31's, rebuilt engine, intake, new head, new injectors, new afm, 2.25 exhuast, header etc...
SOLD: TR: 81 sr5 pickup. 5.29's spool rear, detriot front, highsteer, 36 sx's, lifted, bobbed, cagged, 22r with header, 32/36, 261 cam, new head and rebuild.
Residing in the PNW bham 360
neilan is offline
Old 12-30-2007, 04:54 PM   #13 (permalink)
RiNkY's Avatar
Quote:
Don't learn tho if you don't try stuff yourself. It is nice to know that a local guy is the Diff / Gear guru tho.
__________________
RiNkY
RiNkY is offline
Old 12-30-2007, 05:00 PM   #14 (permalink)
i wouldn't be afraid of tackling this job yourself, get to know your truck, bonding!!!!!!!!
Old 12-30-2007, 05:02 PM   #15 (permalink)
don't need to be a gu-ru to instal an aussiee..
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Aussie Locker Install jforte5650 Offroad Tech 6 12-20-2007 09:15 PM
Aussie locker dlbrunner Offroad Tech 5 11-07-2005 09:03 PM
Aussie locker desert whomper 95.5-2004 Tacomas & 96-2002 4Runners 5 02-15-2005 05:44 AM
Aussie locker install Nathan Buchanan Offroad Tech 18 11-29-2004 06:52 AM
Aussie Locker Jonathan Offroad Tech 35 10-05-2003 10:20 PM
2009 InternetBrands, Inc.
