adjusted tps, now odd stutter in rpms
Old 05-10-2008, 08:30 PM
skinnyhb's Avatar
i just adjusted my tps and everything fell into spec. i started it up and shorted the terminals and the rpms dropped as they should. i drove it around and at one stop light the rpms would intermittently drop like it wanted to die. however, once it warmed up, it stopped happening. i havent driven it since, so im not sure if it was just something working itself out, but im wondering if it could be one of a few things:
- i misadjusted the tps too far back
- i have a vacuum leak from the hoses i disconnected
- i cleaned the thottle body pretty good and i wonder if some of the crap that came off happened to fall into the intake.
- my idle is set too low (before i adjusted the tps, i could nudge the throttle back into idle, and it was only at like 750rpms)
- or i have a vacuum leak because i dropped and (and lost) the nut that goes on the male bolt that attaches the throttle body to the intake.
- sub question, what size is that nut (12mm x ?)
any other ideas? it runs much better than it used to, so im pleased about that, but im concerned about that random drop in rpms.
kenny
Old 05-10-2008, 09:49 PM
abecedarian's Avatar
coolant temp sensor faulty?
Old 05-10-2008, 10:24 PM
skinnyhb's Avatar
perhaps, however, it has never done it before. it feels more like the vacuum leak type intermittent idle drop/surge that i had before i replaced my pcv valve.
Old 05-10-2008, 10:31 PM
well then, check for vacuum leaks- spray wd40 around until you hear the idle drop.
If that don't work, grab the multi-meter and check the coolant temperature sending unit.
Blamalam
03-12-2022 07:34 AM
Sleaker
08-26-2020 06:03 AM
Sarcazmo
08-15-2015 08:22 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: adjusted tps, now odd stutter in rpms
