ADD front axle shafts
Old 10-29-2009, 05:38 PM
dustins's Avatar
Are the axle shafts on add fronts ends the same from passenger side to driver side, when searching for replacements it shows a lot that say passenger side but I dont see any the specify drivers side.
Old 10-29-2009, 05:48 PM
SigEp4Runner's Avatar
I just replaced my CV shafts and they were exactly the same. Im guessing this is what you are talking about. I just went to the parts store and asked for 2 cv shafts. When I looked around online I saw some sites that said drivers side or passenger side, but they are the same thing from what I can see. I imagine this is the same for all models, but I drive a 2nd gen so I am only 100% for my model. Hope this helps.
Also when i tore mine all apart both sides were identical.
Old 10-31-2009, 09:47 AM
highonpottery's Avatar
CVs should be pretty much the same for either side, but if you're talking about the actual axle shafts that are inside of the IFS diff, then no - they are different lengths. the passenger side (short side) is only a couple inches long and the driver's side (long side) is a 2-part shaft with a gear that connects the two when your ADD engages. non-ADD axles have a solid longside axle since it does not have the ADD mechanism.
oldirtydirt
02-23-2020 09:30 AM
A2theK
01-10-2016 10:18 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
Quick Reply: ADD front axle shafts
