94 xtra cab 4x4 suspension lift
Old 10-28-2007, 08:13 PM
tc
tc's Avatar
Want travel/flex?
Keep it stock height. BJ spacers + relaxed tbars + low profile bumps for compression in the front, longer shocks, brake lines and lose the sway bars and it'll flex pretty good for little/no money.
Old 10-28-2007, 09:44 PM
4x4YOTA's Avatar
Originally Posted by tc
Want travel/flex?
about how much travel will I get with that set up
Old 10-29-2007, 05:58 AM
tc
tc's Avatar
Enough.
Seriously, if you're interested in "inches" or ramp numbers you're gonna have to spend some bank and SAS.
The truck performs best when it's balanced front and rear, and you're only gonna get so much out of the IFS, so a ton of rear flex is "wasted" IMHO.
Old 10-29-2007, 06:50 AM
elripster's Avatar
It is good to try to keep all 4 tires on the ground, however, if trail prowess is what you are after, flex comes in second to lockers (traction).
Lifting the front a bit will improve flex some and also allow you to absorb larger hits without bottoming. That can be nice if you are playing in sand dunes or on fire roads.
One thing to remember and this is not a good or bad thing, just an observation, when the truck is crossed up, the part of the truck with the most easily flexed suspension will flex the most (duh). You could find that the front flexes very little and the rear a lot if you have very soft rear springs. However, you might also find you have all 4 tires on the ground when that person with stiff rear suspension, who's front end seems to be flexing more, is lifting a wheel and losing more traction as a result.
However, the guy with little lift and bald tires but with a locker will out perform both of the above mentioned trucks if they have open diffs.
Frank
Old 10-29-2007, 06:53 AM
  #25
elripster's Avatar
Originally Posted by 4x4YOTA
but Im trying to go cheap is the thing... and I have to weld new hangers for the 63" chevies any ways
If you want to do the cheap thing, get some longer shackles and a 1" lift block for the rear. Also, get some longer shocks.
Really, you should try to save up for a locker. You won't be disappointed.
I have wheeled in my friends Pinzgauer which is a front/rear independent suspension flexless machine with lockers front and rear. It spanks built flexy trucks on the trail that have only one locker.
Frank
Old 10-29-2007, 10:24 AM
  #26
4x4YOTA's Avatar
yeah thats trueI would love to havea locker but my truck is also my DD and the ARB is way expensive
Old 10-29-2007, 10:43 AM
  #27
elripster's Avatar
Do you drive on icy/snowy roads? If not, there are some inexpensive locker options for you.
Frank
Old 10-29-2007, 12:18 PM
  #28
4x4YOTA's Avatar
yeah I do I live in colorado and we tend to get snowy/icy roads
Old 10-29-2007, 03:09 PM
  #29
elripster's Avatar
I see, yeah an auto locker is not for you. A Truetrac will will help especially with some ebrake assistance but it's not terribly cheap. I love them in the snow though. If you can find one used it would be a worthwhile upgrade to tide you over until the ARB.
Frank
Old 10-29-2007, 08:06 PM
  #30
4x4YOTA's Avatar
yeah I would love an ARB but not any time soon and ill definately keep an eye out for a true trac
Old 10-29-2007, 08:07 PM
  #31
4x4YOTA's Avatar
my BJ spacer came today and let me tell you I am excited ...
Old 10-29-2007, 09:25 PM
  #32
Luvmeye22re's Avatar
I drove around an 80 toy on big tires here in Colorado with a detroit in the rear. It really was not bad in the winter. I'd say the worst part about it is it limited 2wd snowdriving but if you put it in 4wd, you were ahead of the rest. As far as really cheap rear lift, you've got it, a block. A shackle might suit you a litte better than a block but new springs would be the way to go.
Old 10-30-2007, 05:27 AM
  #33
AxleIke's Avatar
I do not recommend blocks. Shackles are a bandaid, but work.
Both OME and Downey sell springs that will keep you well under 3" and provide you with a little more flex than stock. If you put chevies on, you'll have a bunch of flex in the rear, but still none up front. And since you want to SAS, you'll not be staying under 3" for long. Get the cheap springs that fit in the stock location stay under 3", then when you go SAS and sky high, you can get the longer springs.
Old 10-30-2007, 06:07 PM
  #34
Trustyrusty's Avatar
Damn, my truck is stock and flexes more than that, take out the booty fab blocks and the T-Bar crank, and get some balljoint spacers and longer shackles, a good set of shocks can always help. Also take that junk ass sway bar off of it!
Old 10-30-2007, 06:24 PM
  #35
4x4YOTA's Avatar
I have BJ spacers they came via UPS 2 days ago and I have new shocks and Im waitng on my shackle
  #36
4x4YOTA's Avatar
any one have good pics of there BJ spacer install
Old 10-31-2007, 07:50 AM
  #37
elripster's Avatar
www.4crawler.com and www.sdori.com have instructions.
Frank
Old 10-31-2007, 07:57 AM
  #38
4x4YOTA's Avatar
how much do I need to cut out of my A-arm to fit the spacer?
Old 10-31-2007, 02:50 PM
  #39
elripster's Avatar
Not much, .5"? I never actually measured it, I just hold the spacer up under the a-arm and trim a little. If I need more, I trim a little more. It's very easy to do. If you use a 4" cutoff wheel it goes real quick. Do NOT grind because it takes much much longer.
Frank
Old 11-01-2007, 07:59 PM
  #40
4x4YOTA's Avatar
does it matter if I use my 4.5" angle grinder with a cut off wheel
Quick Reply: 94 xtra cab 4x4 suspension lift
