94 v6 4wd when to change o2 sensors
Old 11-10-2006, 06:40 PM
wishmaster22's Avatar
Originally Posted by williemon
When the OD light lights up after you press the OD button, you should not be in overdrive. Major mileage killer. When the button is pressed in, OD light comes on, truck goes into overdrive.
Light won't come on in either position.
Old 11-10-2006, 07:29 PM
mt_goat's Avatar
Is it just the light or does it not go in and out of overdrive either?
Old 11-10-2006, 10:08 PM
^VooDoo^'s Avatar
Dont wait for a CEL from a bad o2 sensor, Mine went out almost 3mo ago and no CEL and nothing about it pulling the codes myself, I went throught everything to find out why I was get such crappy power and 8mpg.
Read on the net how they work, Went to autozone picked one up and whalla its back to normal.
Old 11-11-2006, 12:59 PM
Not sure, How can u tell if you are in overdrive?
Old 11-11-2006, 04:13 PM
  #25
mt_goat's Avatar
Get going about 60mph and hit the button, when it drops out of OD the rpms will go up.
Old 11-12-2006, 07:20 PM
  #26
williemon's Avatar
You should be running around 2500 rpm in OD at 60 and around 3500 to 4000 out of OD.
Old 11-13-2006, 04:36 AM
  #27
scrid's Avatar
But make damn sure your at operationg temperature or the overdrive will be locked out and wont shift one way or another. The light will still go on and off but it won't do anything else. I thought I had a problem with mine all the sudden but I found out the engine wasn't getting warm enough with the beginning of winter season and had to slip a piece of cardboard in front of the radiator. Now it warms right up and shifts fine, and I don't have to fix anything.
Old 11-13-2006, 06:22 AM
  #28
suprathepeg's Avatar
You're all wrong the truck has a VAFM, jeese get it straight (jk).
Old 11-13-2006, 06:52 AM
  #29
mt_goat's Avatar
Yeah actually if you want to get it really really really straight the FSM calls it a VAF.
http://personal.utulsa.edu/~nathan-b...92volumeai.pdf
What does (jk) mean?
Old 11-13-2006, 08:14 AM
  #30
Just kidding
Old 11-13-2006, 08:25 AM
  #31
mt_goat's Avatar
Just kidding
Oh I was thinking something like that.
Old 11-13-2006, 08:54 AM
  #32
highway74's Avatar
How many o2 sensors does a non CA 3.0 have? I thought I only had one on the exhaust after the cat, which I changed. I did o2, cap, rotors, wires, plugs, air filter, fuel filter with maybe a 1mpg gain. Just did the TPS. All oem parts, I guess they needed to be done, but what waste of money for no real gain. Truck has 105,000.
Old 11-13-2006, 09:55 AM
  #33
mt_goat's Avatar
Mine only had one before the cat. (93, non-Ca.)
Old 11-13-2006, 06:29 PM
  #34
itsmeagain5789's Avatar
does the california and the non california give you the same gas mileage?
o yeah, and voo doo, what do you consider "normal" gas mileage?
Old 11-13-2006, 07:00 PM
  #35
IIRC the purpose of the cali setup is to throw a CEL when your Cat is toast.
Old 11-21-2006, 11:35 AM
  #36
wishmaster, did changing your o2 sensor work for you? if they did, which ones did you change?
Firefightersink15
11-23-2015 10:32 PM
shredder4286
10-01-2015 01:09 PM
accuracy
09-20-2015 07:44 PM
larrys93pickup
09-17-2015 07:05 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: 94 v6 4wd when to change o2 sensors
