94 3.0 slowly overheating at ~30 minutes.
Old 12-14-2014, 07:55 PM
Jknubbles27's Avatar
Hey guys,
So I've finally got my 1994 3.0 back together after blowing a head gasket (First time doing this large of a repair myself... It was.... tedious). I was very pleased when I went to go fire it up yesterday and it fired right up and sounds / drive great. However, after about 20-30 minutes of drive time the temp gauge VERY SLOWLY creeps over the half-way mark and up (again, goes very slowly once it starts creeping).
I am ordering a new Toyota thermostat, because I think mine might've rusted a bit while sitting for the almost 6 months the truck sat while I worked on it. Does anybody have any information / insight for myself if I am going in the right direction? If not, what other components should I look at?
Cheers,
Jeff
Old 12-16-2014, 02:56 PM
superex87's Avatar
thermostat is a good start. Did yiu bleed the coolant system?
It is highly recommended to jack the front of the truck up as high as you can, with the engine cold open the radiator cap, start engine and add coolant until it wont take any more. Its common for the 3.0 to have air pockets in the cooling system causing over heating.
the1998sr5
27
11-17-2015 09:30 AM
Tennesseestorm
09-12-2015 01:37 AM
Alex Bessinger
08-31-2015 09:17 AM
accuracy
08-30-2015 09:47 PM
Logz808
07-26-2015 07:09 AM
Quick Reply: 94 3.0 slowly overheating at ~30 minutes.
