Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
94 22re swapped for 87 22re
The deal is that i've got a frankenstein truck, 87 4runner frame, 85 cab, 94 22re, 92 w56 tranny, and i threw a connecting rod! i've got a line on a 87 rebuilt 22re and was wondering if it's gonna be a big hassle to swap the motors? i've heard that the injectors might give me problems, but i'm thinking i should be able to use my 94 harness and everything should hook up except the fuel rail, so i'll just swap in my 94 fuelrail and injectors! Let me know what you guys think! Thanks
| Sponsored Links |
#2 (permalink) |
I did almost the opposite swap.... I put a '94 in my '88. I pretty much just used the '94 long block and swapped over the intake manifod, plenum, fuel rail with injectors, and accessories, and kept my '88 harness.
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s Last edited by rdlsz24 : 05-23-2008 at 07:11 AM. |
#3 (permalink) |
It's funny cause the frame of my truck is from an 87 runner and the cab from a 85 PU, but the engine is out of a 94 and i just broke a rod. The enigine i found for sale is out of a 87 and the guy was trying to put it in a 90 and couldn't get past the injectors! i think i'll do the same as you, just use the 87 block and swap my 94 manifold, fuel rail and injectors over. Thanks for the advice, but anyone else is welcome to add!
#4 (permalink) | |
Quote:
Rob
__________________
1988 Xtra Cab Pickup ('94 22RE; 4x4; 5spd) Rancho lift w/ 33x12.5x15 tires & 5.29s Last edited by rdlsz24 : 05-29-2008 at 03:32 AM. |
#5 (permalink) |
heh heh the injectors changed several times. BEST policy is just change the longblock, keep the intake and sensors intact.
#6 (permalink) | |
wait you mean to tell my that a pick up frame will work under a 4-runner???
cause i passed up a 100 buck pick up good frame cause i though it wouldnt work??? ps everything else was gone or i would have got it
__________________
GO TEAM LAZY!! my name is ALLAN yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear Quote:
www.myspace.com/whatsadisplayname |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22re performance valve springs - 22r/22re $70 | dcg9381 | Misc Stuff (Vehicle Related) | 0 | 02-05-2007 07:17 PM |
| Will a Knock Sensor from an 87 22re PU work on a 90 22re PU | tlake | 86-95 Trucks & 4Runners | 2 | 10-24-2006 07:49 PM |
| 87' 22re and 89' 22re ecu compatability | surtur | 86-95 Trucks & 4Runners | 1 | 12-11-2005 07:41 AM |
| Rough idle on swapped 22re... Any ideas? | NotMatt | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 06-10-2005 08:13 PM |
