94 22re rough idle then dies
Old 07-23-2014, 06:11 PM
Hudjack12's Avatar
Hey guys I had a hole in the timing chain cover and got that fixed. Now the truck will start and idle rough then die.The fuel pressure is low and have Replaced the fuel pump but that did not help anybody have any other ideas. Thanks
Old 08-19-2014, 06:11 AM
hookem_horns's Avatar
I'm having the same issue. My next step is going to be dropping the tank and clearing the fuel lines. Good luck.
Old 08-21-2014, 06:16 AM
hiluxhack's Avatar
If it ran well before you fixed the timing cover, it must be something that happened while you did that. I'm sure you looked for vacuum line problems but check for cracks that can't be seen by wiggling them or pinching them one at a time with needle nose pliers. Also, look closely at the intake hose at the throttle body. They can crack underneath or just be loose enough to leak. Good hunting.
Charecter1
11-06-2023 10:08 AM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
v_man
07-23-2015 04:01 PM
Quick Reply: 94 22re rough idle then dies
