93 4runner differential
Old 02-27-2014, 12:09 PM
kracken1991's Avatar
I got a 93 4runner with a 7.5 rear diff wanting to know if an 8 inch will fit in the axle hosing
Old 02-27-2014, 01:52 PM
Sturmcrow's Avatar
Nope!
Old 02-27-2014, 03:05 PM
james92toy's Avatar
I think you mean you have a 7.5 in the front and a 8" in the rear.
http://home.4x4wire.com/erik/diffs/#v6/turbo
Old 02-27-2014, 03:21 PM
How do you check for ring size
Old 02-27-2014, 03:27 PM
james92toy's Avatar
To check ring gear size you would have to pull the 3rd out and measure. If your rear axle is stock it should be a v6 rear 8". What makes you think its a 7.5?
Old 02-27-2014, 03:34 PM
I assumed it was when i had got a pinions seal for an 8" and it was to big and started pouring out then i got the next size down and it stopped
Old 02-27-2014, 03:43 PM
james92toy's Avatar
Another way to identify is to look at 3rd housing . Some have more or less "ribs"
On the sides . I don't think they make a 7.5 rear or if they did it would be for a car . Weird
Old 02-27-2014, 04:09 PM
JasonYota's Avatar
They made a 7.5 rear in the 2wd trucks. If the rear axle is stock is a 8in.
Old 02-27-2014, 04:33 PM
How many ribs for what
Old 02-27-2014, 04:38 PM
james92toy's Avatar
I don't remember , try looking it up on pirate. FAQ
Old 02-27-2014, 04:39 PM
How many splines are on the 8" axle shafts
Old 02-27-2014, 04:43 PM
JasonYota's Avatar
See post above.
Old 02-27-2014, 04:53 PM
james92toy's Avatar
Repeat. Don't ask. Look up in Toyota FAQ
Old 02-27-2014, 06:12 PM
Thank you
Old 02-27-2014, 07:11 PM
cman1's Avatar
unless its a two wheel drive!?
Old 02-27-2014, 08:02 PM
No its a 4x4
Old 02-27-2014, 08:45 PM
Punchy's Avatar
The 4 cyl 8" carrier has a smaller seal and bearing set, But both fit into an 8" axel housing and axels.
Old 02-27-2014, 09:03 PM
What would be the best lsd or locker
Flying91
45
04-11-2024 04:39 PM
Ladythump
22
11-09-2015 08:53 AM
jerusry
10-19-2015 05:28 PM
BeMiceElf
10-10-2015 09:40 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: 93 4runner differential
