92 Clock
Old Mar 17, 2006 | 02:30 PM
FOCUSHERE's Avatar
92 Clock
Just bout a clock off Ebay and there are no obvious attaching points like a crew were the bracket is so... how does this attach?
Old Mar 17, 2006 | 02:52 PM
freshman's Avatar
90-95 toyota 4runner clock has 2 screw holes. when you look it from the front, it should be on the upper left and lower right of the square clock. If what you got is without this mounting holes, then you have the 84-89 clock which i dont thing will work.
about installing:
if you dont have a factory clock before, there is a punch out hole you need to remove part of the heater faceplate (left side) and the wire harness for the clock is also inside of the punch out hole. In order to be able to install the clock, you need to remove the center console as in installing an aftermarket deck unit.
hope it helps.
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Chicken12
Oct 14, 2015 03:54 PM
seab1209
Sep 3, 2015 05:41 PM
