92 22RE TPS Code 41 and 51
Old 03-06-2012, 08:24 AM
BajaToy616's Avatar
So i had a code 41 and 51 on my 22re tps? well i removed my tps and looked at it and the one advance gave me had a different plug design so i put my old one back on and the motor surges terribly.....so i unplugged it and screwed the idle screw down all the way and it ran fine for a day and a half acctually it ran a hell of alot better then my codes came back and it ran like ˟˟˟˟ i ordered an throttle body off of ebay with a good tps on it.....if i just bolt that throttle body on my motor should it run or what will i have to do
Old 03-06-2012, 08:41 AM
jrock08's Avatar
I'm relatively limited as far as expertise goes, but I would think that the throttle body would be plug and play(assuming its off another 22re). I'm sure somebody will come along that knows more than and give you a for sure answer. I was just going to tell you don't be surprised if that doesn't fix it as I had similiar problems and it ended up being a burnt valve. Wish you better luck than me. lol
Old 03-06-2012, 08:46 AM
BajaToy616's Avatar
Did you also get those trouble codes???? the other thing i forgot to mention is that there was a small hole in my fenderwell spraying water on my ecu
do you guys think that my ecu is screwed
Old 03-06-2012, 09:20 AM
jrock08's Avatar
Yes mine was throwing the same codes. You can pull plug wires to do a quick easy check on the valve. As far as the ecu goes I would think you SHOULD be alright as its SUPPOSED to be sealed but can't promise anything.
Here is a link to 4crawler's site which is a very useful way to check your TPS:
http://www.4crawler.com/4x4/CheapTricks/index.shtml
Hope this helps!
Old 03-07-2012, 07:05 AM
BajaToy616's Avatar
Did your motor run fine
before you messed with the tps
Old 03-07-2012, 07:31 AM
BMcEL's Avatar
You're going to replace the entire throttle body because of a possibly bad/misadjusted TPS, without actually testing the TPS?
Test/adjust your TPS. Replace with OEM if it's out of spec. Putting aftermarket sensors on these trucks is asking for trouble.
Old 03-07-2012, 02:00 PM
BajaToy616's Avatar
I did everything 4crawler told me to and it still didnt run properly and a new tps cost more than the factory throttle body with a factory tps on it off a awesome running truck but its frame broke so hes parting it out but i wanted to know if it will be plug and play thats all
smthwsn357
12-04-2023 02:08 AM
montanatruck
02-26-2017 07:07 AM
Cbr954ryder
07-25-2015 06:32 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
jake_v
07-22-2015 03:17 PM
Quick Reply: 92 22RE TPS Code 41 and 51
