91 pickup w/ V6 Gears
Old Nov 27, 2007 | 04:43 AM
inras89's Avatar
Does anyone know how do I find out what gears I have in my rear?
Or Does any one know?
and what is a good gear ratio for running 35" tires?
Thanks
Old Nov 27, 2007 | 06:29 AM
colsoncj's Avatar
search and you shall find
Old Nov 27, 2007 | 07:50 AM
LS1Steve's Avatar
block front tires.
jack up ONE rear tire and put shifter in neutral.
Put a piece of tape on driveshaft, and another on tire wall. Spin the tire ONE revolution, while paying close attention to the driveshaft....count the number of driveshaft turns....this is your ratio. (you will have to guestimate, but very easy.....ie: if it spin between 4 3/4 and 5 turns...you probably have a 4.88).
with 35's? ouch. I have 33's and run 5.29:1. I couldn't imagine using any less. With your 35's, i'd probably go 5.29, or maybe higher as long as you don't do mostly freeway.
Old Nov 27, 2007 | 08:13 AM
seafarinman's Avatar
Nevermind the gears you have in the back. Order some 5.29's, have them installed and proceed smartly.
Old Nov 27, 2007 | 08:27 AM
jason191918's Avatar
http://www.brian894x4.com/Gearratiosanddiffs.html
http://www.4lo.com/4LoCalc.htm
How many times do I have to post these links?
Old Nov 27, 2007 | 09:04 AM
inras89's Avatar
Thanks jason191918 I have 4.10's.
I do alot of Highway Driving what gear ratio do you suggest for the 35" tires.
kawazx636
Oct 6, 2021 03:03 PM
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
irv
Oct 1, 2015 09:49 PM
whiteyota93
Sep 29, 2015 02:31 PM
charlie_fong
Sep 27, 2015 10:06 PM
