91 4runner head removal help!
Old 11-11-2015, 03:50 PM
mattthomas78's Avatar
Ok, so I bought a 91 model 4runner with 3.0 and blown HGs imagine that... I've removed all the intake bolts and nuts, head studs and down pipe on the exhaust. The problem I'm having is the front of the heads and intake are loose but for some reason I'm having trouble with the back of the motor coming loose. Am I missing something? I've done my best searching this forum for an answer but so far haven't found the answer I'm looking for....
Any help will be greatly appreciated!
Old 11-12-2015, 09:06 AM
Janos01's Avatar
Can you please post some pics so we can better identify your problem?
Old 11-12-2015, 09:32 AM
Sure! Let me get to the house and I'll get a few shots and post them up.
Old 11-12-2015, 10:31 AM
Driver's side head.
Top view of passenger side head and intake. I loosely left to two nuts on the studs in front of intake.
Rear of intake. Broke one of the studs of trying to remove the nut.
Passenger side head bolting removed from head...
Driver's side head closest to the firewall. Notice the crossover piping to the right.
Close up of boring removed from driver's side head closest to the firewall
Exhaust loose from the driver's side header
Old 11-12-2015, 10:43 AM
I'm able to pick up the front on the heads and intake but the back of the heads and intake aren't loose for some reason and I can't figure out why... I cannot remove the intake by itself because the two studs in the back that go thru the intake and into the heads is "seized up" and it won't let the intake slide up the bolts...
I've tried to pry the intake loose from the heads but it won't budge... So I decided that I would try to pull the heads with the intake, exhaust headers and crossover piping attached but again too no avail....
Jayboy74
10
12-21-2021 08:27 AM
Anthony Lee Mathis
09-15-2015 07:22 AM
FJtoyman
09-08-2015 04:47 AM
Tacoma1313
08-29-2015 12:34 PM
juandulce4runner
08-21-2015 07:30 PM
Quick Reply: 91 4runner head removal help!
