'90 4Runner Engine rebuild or swap?
Hey, My buddy gave me his old '90 4Runner 4x4 that he bought brand new back in the day that is currently at 357K all on the original engine.
Its leaking a lot of oil from the front seal and from the rear seal. Needs a timing belt change and a couple of other things. I figured I'm just gonna pull the engine and work on it and contemplating a rebuild. The valves are really noisy.
I've never done anything this complex, but I'd like to learn.
I just dont want to throw money at a lost cause. Would it be easier to just get my same engine out of a wrecked car and put it into mine? But then I don't know what could go wrong with that in a little while. At least with my current engine I know what I need to fix... Of I could attempt some sort of swap and get a newer engine but I'm not even sure what that will cost.
I'm gonna start pulling my engine but I don't know what to do from there haha. Any ideas? Trying to do this the most cost effective way?
Thanks and sorry for noob-ness.
The fact that your current engine is running, shows that there are probably no issues with the block or head(s) that would prevent a successful rebuild.
I would rebuild what you got, if it were mine.
You got 4 cyl, or v-6?
My question with that kind of mileage what kind of shape is the rest of the 4Runner in??
What is your long term goal here??
A weekend off road vehicle or a daily driver to commute the 100 miles to work every day??
The 3.0 is what it is some love them some hate them and the whole range in between.
It could be time for a ground up rebuild
Well, the first thing I did when I got it is paint it (my dad enjoys that portion) so body wise the car is in really nice shape. Interior needs a little bit of work on some of the seats but for the most part it was well kept.
Long term goal is kind of up in the air. I would like to keep it and make it my car when I'm up at school because it would be nice to have 4wheel drive in the winter and I am only like 2 miles from campus. BUT I have yet to figure out the starter problem where it just *clicks*. I've read alot of threads and am stuck. The original starter is gone (my friend said he replaced the starter like 3 times with remanufactured ones) and always had the same problem shortly after so he just banged on it. I got one, checked the contacts, looked fine; put it in and have started getting click just a month later. If I can't fix this, I don't want it as a daily driver.
I was not thinking about the body that is the least of my concern Most all my Toyota`s have at least 4 or more different colors .
I was speaking of the mechanical condition Steering and Suspension and Brakes.
The brake and fuel lines.
Those unimportant things to some people.
Most of that stuff is in really good shape. Seems fine. Im thinking about just replacing the seals and running it until it dies haha. But If thats all i do, do i need to pull the engine at all?
You need to pull the engine or the tranny to access the rear main seal.
Might be best to pull the engine to reseal 'cause then you can more easily access many of the hard to get to vacuum and small water hoses that cover the 3vze.
Y'all have been really helpful! Much better than when I was driving nissan and needed help in their forums haha!
Anyone know where I can find a good engine removal thread with pictures? I have the manual but my problem is, I have difficulty knowing/locating all the hose and other stuff that needs to come off.
You do it the same way. Usually you do a compression test with the engine still in the vehicle and if the test shows bad then you pull the engine for repair or rebuild. Not normally pull it first.
my 2 cents.
I wanted a 4runner for more room inside, but I'm going with a V8.
BTW I have a complete 3.4 with an automatic for sale.
Update, I perfomed the compression test. 1 stood out. I got 0 compression in cylinder #3 dry and it increased to about 50psi when i added oil. 5 and 1 were both about 150. What does this mean?????
