'90 22R PU leaking oil
Old 10-05-2009, 10:59 AM
516593812's Avatar
My '90 22R (4spd manual/Carb/ RWD- not my 4x4) is leaking about 8 drops of engine oil per night (10-12 hour period) It's definitely engine oil, coming from right under the engine. The 22R is otherwise solid, not tired at all, great power/ torque, smooth & quiet. Currently at 175k on original engine/ tranny. How would I find the source? What are some common leaks on these? I don't really want to start tearing it up to check- I don't mind the small leak, but it would be nice to get rid of. How about that "rear main seal repair in a bottle" stuff? If I found the source of the leak, could I put something on it externally? (ie: JB Weld, RTV, etc.) Any ideas/ suggestions?
Thanks!
Old 10-05-2009, 11:27 AM
Staff
DeathCougar's Avatar
Start by cleaning the motor. Clean all the oil off.
Then check where the leak is coming from.
And whatever you do, DON'T use that seal-repair in a bottle crap. If its designed to block oil from leaking, its going to block oil from flowing.
Old 10-05-2009, 11:30 AM
516593812's Avatar
Cool. I'll degrease it. Is it ok to use a pressure washer?
Old 10-05-2009, 01:59 PM
pruney81's Avatar
just get some purple power and a rag and wipe it off under there
jasonty
41
12-23-2018 01:00 PM
Ladythump
22
11-09-2015 08:53 AM
cars-guy
07-11-2015 07:51 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: '90 22R PU leaking oil
