**89silverpu's e-locker retrofit build**
Old 06-02-2009, 09:24 PM
89silverpu's Avatar
Finally got to retrofitting my e locker with 4.88's into my truck. I had a local shop cut, weld, drill, and tap everything since I don't have the tools necessary to do that.The simple version...
EDIT:
Tools/parts you will need:
- e-locker third from a TRD 4x4 Tacoma or a 4runner with the factory e-locker
- Toyota factory e-locker gasket to mark where to cut out and drill holes
- Toyota factory e-locker studs (long)
- Electronic actuating harness/switch (got mine from 12voltguy.com....highly recommended)
- 17/64" drill bit
- 8mmx1.25 tap
- I had a local welding shop modify my axle, but if you're going to do it yourself...Welder, plasma cutter, drill press (could use cut off wheel instead of plasma cutter just takes longer)
- 4'' angle grinder
- Good file to even out surface after adding extra bead of weld
- spray paint
- brake clean
- RTV Grey gasket material
- Tools necessary to remove rear axle assembly
Note: if you are setting up your own gears, you'll need a regular 8" ring and pinion in whatever gear ratio, but you'll need an e-locker specific install kit.
Take the axle out...
After taking the third out, take out the three studs you will not be using...
Put on the toyota factory gasket and mark where the holes need to be drilled and what needs to be cut out...
(next 2 images taken from 4x4wire.com write up)
Cut, drilled, and tapped with extra material added on the outside of the newly drilled and tapped holes for more surface for the gasket to seal...
E-locker third slid into place after cleaning all the metal shavings out really well and coating the rim with ultra gray gasket maker (axle must be in locked position)...
All painted up...
Now tomorrow I'll finish getting the axle back in the truck, bleed the brake lines, hook up the wiring harness, and I'll be ready to go. Gotta break the new gears in nice and slow. I'll post up finished pictures when I'm done.
Sorry for the quick write up, I'll go into more detail when I have more time!!
Old 06-02-2009, 09:36 PM
scuba's Avatar
DAMN !!!
Congrats man !!
You scored on that setup
Old 06-02-2009, 11:52 PM
space-junk's Avatar
oh man, your gonna love those 4.88s...
congrats on gettin a nice score...
Old 06-03-2009, 06:04 AM
89silverpu's Avatar
Thanks guys, after I get this all taken care of, I just gotta put my front 4.88's in and break the gears in then I'm plannin a big wheelin trip up to Eagle Lakes/Fordyce at the end of June to pop it's cherry
Old 06-03-2009, 08:13 AM
RMA
RMA's Avatar
Dude Great job , looks good .
Now I want one...
Hey I see they also added a bit of material on the right for the 2 bolts.
again Nice Job...
Old 06-03-2009, 10:41 AM
RustBucket's Avatar
Did the pound the back of the housing out a little bit to clear the larger gear?
Old 06-03-2009, 11:31 AM
toyNG's Avatar
I'm so jealous!!!!
Old 06-03-2009, 12:36 PM
89silverpu's Avatar
Now I want one...
again Nice Job...
Yeah I forgot to mention that too. You have to add the extra metal out there to make room for the stud hole and to add more material for the gasket to bond too. Thanks!!
No I pounded down the bottom of the "pumpkin section" to clearance for a bolt that sticks out a little farther than the stock third. The gears are the same size, 8''.
Originally Posted by toyNG
I'm so jealous!!!!
haha you've got 4.7's...we'll call it fair
Old 06-03-2009, 02:25 PM
Lama glama's Avatar
Man, that looks great! Thanks for the good pics! I really want to do this mod.
Old 06-03-2009, 02:31 PM
Junkers88's Avatar
Man that looks great!!! CONGRATS!!!!!!
I want to do this when I regear to 4.88's front and rear but finding an E-locker for less than 800$ is almost impossible out here.
Old 06-03-2009, 03:20 PM
RMA
RMA's Avatar
junkers there is a guy on ebay that always has them for $350, somtimes less $300
Old 06-03-2009, 04:23 PM
874runnersr5's Avatar
Man im jealous,
looks good dude keep up the great work
Old 06-03-2009, 07:14 PM
89silverpu's Avatar
I just got in from finishing it up and takin it for an easy drive to break the gears in I'll have final pictures up on here as soon as they are uploaded from photobucket
No problem I had a lot of fun....as well as frustration lol
Thanks!! I know, they are expensive, I got really lucky with such a good deal on the new gears and everything too!
Originally Posted by 874runnersr5
Man im jealous,
Thanks!! Too bad you didn't wanna trade your 4runner for the third member
Old 06-03-2009, 07:32 PM
89silverpu's Avatar
Haven't hooked up the wiring harness permanantly, just enough to unlock the axle so I can drive, I'll get that all hooked up when I have more time, this took a couple days to put together inbetween working and training. On to the pics...
Painted all nice and pretty...
Old 06-03-2009, 07:36 PM
UKMyers's Avatar
Sweet man congrats.. when we going wheeling? What do you think of the 4.88's so far?
BigBluePile's Avatar
Man that is a cool mod! I might just have to be on the look out for that!
Old 06-03-2009, 07:39 PM
Lama glama's Avatar
Do you know how I might find this guy? I searched but didn't find much.
Old 06-03-2009, 07:42 PM
89silverpu's Avatar
The 4.88's are soooo nice! When I was out drivin lightly to begin the break in process all I wanted to do was gun it haha I'm goin up to Eagle Lakes/Fordyce the weekend of the 27th/28th of June (possible two day trip, maybe a one day on sunday, we'll see) that I'd love for you to come! I'll give you more details as soon as I know!
Yeah man, wait till you can score a deal on one or it's gunna be anywhere from 800 to a grand for just the third I got mine for like half that!
Old 06-03-2009, 07:46 PM
Wow, that's definately a wishfull thinking project then! lol!!
Old 06-03-2009, 08:10 PM
iamsuperbleeder's Avatar
now I want to do this...
maybe I need to finish my motor rebuild first
good job man!
Quick Reply: **89silverpu's e-locker retrofit build**
