'89 4x4 w/ 22re engine: Trouble Code 12 - RPM Signal
Old 08-15-2011, 10:38 AM
cLandstreicher's Avatar
The other day my engine light came on so I ran a diagnosis and came up with trouble code 12. My Chilton's indicates that this is due to having no NE signal being input to the ECM for 2 seconds or more after STA turns ON. It identifies the NE circuit, distributor, STA circuit, and/or ECM being the trouble area. Does anyone know how to test these areas; in particular, the NE circuit and STA circuit. Advice on where to start with this problem would be great, too!
EDIT: It may be helpful to mention that when I turn the key, it doesn't turn over. I have to start my truck by jumping the starter, which works every time. I've had to do this occasionally for about a year, but it has progressed to an every time sort of thing, unless I try starting it immediately after turning it off. Perhaps my best bet would be replacing the ECM.
Ditch Doc
10-27-2015 03:20 PM
kcaudill
10-10-2015 02:39 PM
Jdgarrison
10-01-2015 05:22 PM
Jdgarrison
10-01-2015 02:11 PM
Quick Reply: '89 4x4 w/ 22re engine: Trouble Code 12 - RPM Signal
