88 truck underpowered (and other issues)
NaeSlas,
If you like I can help you with most of your questions. I have an 86 4runner with 33's and 4.88 gears.
If you want you can take a ride in it and see that even with gears these trucks are slow. I can however use 5th on the freeway.
I live down by UNM, PM me if you want.
Robb
Robb
Originally Posted by NaeSLaS
also, i was thinking, if i come to a stop, and put the truck into 4-low, without engaging the manual front lockouts, do i effectively have 2-low? Is this bad for anything? I would assume not, because when they are in free mode, the wheel is turning without the axle, so would it matter if the axle is turning without the wheel?
Rob
4Lo with the front unlocked is... 2Lo
Be aware that the CVs are spinning.
It puts "wear" on the bronze bushings in the spindle... but nothing Id worry about unless your wheel bearings are dry (then you have other issues).
#26
You could always just do a sas that solves all the ifs problems. I hope to be starting mine soon. I got a few more parts I have to get before I can begin. If you need any IFS parts just let me know or any other parts for that matter. I have a bunch of parts I need to sell.
#28
can i ask a quick question? why are those bumpstops there? it looks like they allow around 1.5 inches of travel...then your truck basically hits and feels like its bottoming out? why not let the suspension travel more? would the torsion bars break?
hmmm.... they just look like they're defeating the purpose of having suspension
#29
Take a pen sitting on your desk an pick it up at one end with the other end still sitting on the desk. The end on the desk moves much less. Same idea...
#30
The bump stops are close to the centerline for the torsion bar, there is 6 or 8 inches of control arm beyond that point so the travel is actually much more than the 1.5 inches you see...
#31
Looks like we have the same truck. I have an 88 with 33s on it and stock gears. Get used to the power lag. I just use 5th if there is no hills or anything. 4th is the best on the highway.
#32
ok, so here we sit as of this typing
Known issues:
1) Stolen Stereo (F***ERS!)
2) Window falls out of regulator, due to previous numbnut owner cutting out holes in my door panel for 6x9 speakers
3) bumpy ride, due to add-a-leaf, weak t-bars, and low bumpstops.
4) bent bumpstop, unknown cause, soon to be fixed
5) Power issue solved by bringing timing into check
6) Gearing due to 33's and stock gears...5th is a downhill gear only, but i can use 4th in highway speeds now.
Unknown Issues
1) Driveline lash...time to check the diffs?
2) Clunk when I first start in 1st, driveline lash?
3) 4-lo pops out randomly (rubber boot issue maybe?)
4) Buzz noise occurs at 21mph indicated, any gear. Sounds like a hollow pipe vibrating, like driveline lash too? Most notable in higher gears, like 3rd or 4th.
5) Missing jack and jammed up spare...pray i don't get a flat.
6) whatever pops up tomorrow
FWIW, the bracket lift i have in there has "Trailmaster" embedded on it. Not a rough country or superlift, like we had previously thought. oh well, what does brand matter much in a bracket lift anyway.
also, someone rear-ended me! i was sitting at a light when the police were coming through the intersection, with someone in front of me, and this 2WD s-10 slams into me.
truck damage: dented bumper, bent bumper bracket
s-10 damage: two headlights, grille, crumpled hood, cracked radiator, bent radiator support, trashed quarterpanels to the point of drivers door not opening.
Score another for Yotas.
pics of truck to come soon...downloading my vacation pics from the camera too.
P.S. i'm 21 now, so ATB NaeSLaS
Known issues:
Unknown Issues
#34
Didn't snap pics of the lady's truck, but it was pretty f***ed. and she hit me because she wasn't paying attention.
So here's pics of the truck before, with my buddy's 240sx under the bumper.
(btw, i'm trying out a new hosting service, google's picasa...i don't know if they allow remote linking or not. if these pics are broken, tell me)
so, before the bang-up, with my buddy's 240sx under my bumper
P.S...i call this picture "owned" because thats the full height of my jack:
anyway, here's the damage now
also, here's why the window keeps falling out of track
my missing stereo
adjustable steering stops?
i think i found the popping noise...LOL
my missing stereo
#35
So, as of this typing (reviving my old thread), most of the issues have been worked out.
I welded in supports to hold my new window regulator, and my window works again.
I still have driveline lash, some that was attributed to blown U-joints, but still some diff/gear lash.
I FINALLY have torque/power. When I went to do my timing chain, numbnuts before me had the timing one tooth off. They didn't pre-tension the cams before slapping the chain on. I'm surprised this didn't ruin my engine. I set the timing correctly, and now i have plenty of power/torque. I can actually get some use out of 5th on the freeway.
I have suspension pops, but I'm attributing this to balljoints right now.
I also have a MC rear bumper, that doesn't quite fit because of my body lift, but i'm not gonna worry about it quite yet. I only bottomed out my stock bumper twice.
My 4-low pops out because of the body lift. The shifters don't sit as high as they should. Not really sure what to do about this yet. I found someone (ORS i think) with a modified crossmember to correct for that, but i'm not so concerned with it yet.
ATB NaeSLaS
ATB NaeSLaS
WI Girl
06-25-2015 03:45 AM
saphirekosmos
06-22-2015 10:26 AM
