87 toy vacuum advance
Old 07-11-2008, 01:19 PM
bilzshop2's Avatar
If I set the timing on my 87 22r at 12 degrees with the vacuum hoses attached,and rev the motor to 3000 rpm,should the timing move up or pull down to 0 degrees? I'm trying to figure out why I lose power from around 3000 rpm and up,thanks
Old 07-11-2008, 01:23 PM
abecedarian's Avatar
the timing should advance under high-vacuum/part-throttle conditions and retard under full throttle conditions up to the point where the total advance of the centrifual advance mechanism has been reached.
It should not ever go to 0 degrees... it should not drop below the initial advance setting.... unless you have knock sensing involved and then the knock sensor could cause the timing to drop below initial advance.
Old 07-11-2008, 01:38 PM
bilzshop2's Avatar
I can set the timing on 0 with the lines plugged,then connect the lines and its around 12 degrees,but under any throttle it drops to 0 degrees,the truck pulls fine till around 2800 rpm and up the just seems to lug all the time,any ideas on what to try?thanks
Old 07-11-2008, 06:12 PM
bilzshop2's Avatar
it was the port on the carb causing the problem,I put a vacuum guage on it and it was screwed up,I changed to another port that advanced the timing with the rpm's as it should and the truck scats now
JNapolitano
11-14-2019 07:46 PM
wafoogalla
11-02-2016 11:02 AM
87blyota
08-23-2015 03:57 AM
Sarcazmo
08-15-2015 08:22 PM
rjtrials
08-06-2015 07:25 PM
Quick Reply: 87 toy vacuum advance
